Power supply case
Posted by UkIan
Power supply case
October 27, 2014 08:55AM
I'm using the LED light style power supplies
This sort of thing (pic borrowed from OOZNEST).
Does this form factor have a name? Does it have a standard set of dimensions?
I was looking at buying a cheap case for one rather than print or otherwise build one, but it's not proving that straight forward.
Re: Power supply case
October 27, 2014 09:13AM
I have a very similar power supply, dimensions are 113*51*213.
October 27, 2014 11:01AM
UkIan
I've always seen them referred to as a chassis mount power supply. I've seen them all sorts of sizes so I don't think they are standardized similar to what ATX power supplies are. If you need one to fit in a particular location that has limitations, you're going to need to double check the product dimensions, mounting holes, etc.
October 27, 2014 11:48AM
Fair enough, I'll knock something together myself then smiling smiley Thanks both.
