Do I Need an Extruder Motor Fan If I Build Enclosure Over Print Area?
Posted by Plasteroid
November 02, 2014 09:03AM
Do I Need an Extruder Motor Fan If I Build an Enclosure Over Print Area? Normal printing and open heatbed my motors do not get hot at all. Perhaps not 100% closed, but something against drafts.
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
Re: Do I Need an Extruder Motor Fan If I Build Enclosure Over Print Area?
November 02, 2014 11:32AM
If you planning on printing ABS all the time with an enclosure at 100~120 then you will need a heatsink and a fan, if you looking for an enclosure temperature between 60~80 degrees then just the heatsink. A fan only cooling system is inefficient.
November 02, 2014 01:11PM
ggherbaz
Besides that, you'd have to pump in air from the outside of the box to get cool air.
Or design an enclosure that has a bounding box that keeps out the motors (and use bowden for extruder so that too sits outside the box).
http://www.marinusdebeer.nl/
