Problem with Nozzle touching the print after first layers & more November 03, 2014 10:43AM |
Re: Problem with Nozzle touching the print after first layers & more November 03, 2014 12:42PM |
Re: Problem with Nozzle touching the print after first layers & more November 03, 2014 01:03PM |
Re: Problem with Nozzle touching the print after first layers & more November 03, 2014 01:12PM |
Re: Problem with Nozzle touching the print after first layers & more November 03, 2014 10:23PM |
Re: Problem with Nozzle touching the print after first layers & more November 04, 2014 09:24AM |
Re: Problem with Nozzle touching the print after first layers & more November 04, 2014 12:56PM |
Re: Problem with Nozzle touching the print after first layers & more November 05, 2014 02:05AM |
Re: Problem with Nozzle touching the print after first layers & more November 05, 2014 08:46AM |
Re: Problem with Nozzle touching the print after first layers & more November 05, 2014 10:36AM |
Re: Problem with Nozzle touching the print after first layers & more November 05, 2014 03:10PM |
Re: Problem with Nozzle touching the print after first layers & more November 05, 2014 05:27PM |
Re: Problem with Nozzle touching the print after first layers & more November 06, 2014 09:09AM |
Re: Problem with Nozzle touching the print after first layers & more November 06, 2014 10:55AM |
Re: Problem with Nozzle touching the print after first layers & more November 06, 2014 05:54PM |
Re: Problem with Nozzle touching the print after first layers & more November 07, 2014 12:33AM |
Re: Problem with Nozzle touching the print after first layers & more November 07, 2014 11:53AM |
Re: Problem with Nozzle touching the print after first layers & more November 07, 2014 03:30PM |
Re: Problem with Nozzle touching the print after first layers & more November 07, 2014 04:04PM |
Re: Problem with Nozzle touching the print after first layers & more November 07, 2014 07:01PM |
Re: Problem with Nozzle touching the print after first layers & more November 18, 2014 02:03AM |
Re: Problem with Nozzle touching the print after first layers & more November 23, 2014 08:23AM |
Re: Problem with Nozzle touching the print after first layers & more November 08, 2015 03:41AM |
Re: Problem with Nozzle touching the print after first layers & more November 08, 2015 01:57PM |
Re: Problem with Nozzle touching the print after first layers & more September 29, 2019 07:12AM |
t0bb
nozzle head touching the print layers sounds like over extruding a bit. Try conroling extrusion rate, also layer width
And you cannot print small parts, circles etc, with higher speed unless you print several in the same time. No time for the layers to cool down, and then they bend, smudge...
And the pieces being slightly bigger, with small parts you always have to do some post production. Thermoplastic is a touchy thing especially PLA
that's in my small experience
cheers
