Hey RepPappers!
I am fighting with my i3 prusa I built. X, Y, Z work great but I can not get extruder motor working. I swapped stepstick from extruder to X and tested movement - it worked fine when I moved X! But when I put motor and stepstick back to extruder and tried to move extruder it was silent.
My Marlin Configuration.h does not change much from default, here is a diff:
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h
index d2aba19..82a93d9 100644
--- a/Marlin/Configuration.h
+++ b/Marlin/Configuration.h
@@ -82,7 +82,7 @@
// 999 = Leapfrog
#ifndef MOTHERBOARD
-#define MOTHERBOARD 7
+#define MOTHERBOARD 33
#endif
// Define this to set a custom name for your generic Mendel,
@@ -142,10 +142,10 @@
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
-#define TEMP_SENSOR_0 -1
+#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 -1
#define TEMP_SENSOR_2 0
-#define TEMP_SENSOR_BED 0
+#define TEMP_SENSOR_BED 1
@@ -562,7 +562,7 @@ const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of
// The RepRapDiscount Smart Controller (white PC
reprap.org]
-//#define REPRAP_DISCOUNT_SMART_CONTROLLER
+#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PC
reprap.org]
@@ -572,7 +572,7 @@ const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of
reprap.org]
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [
code.google.com]
-//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
+#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
reprapworld.com]
diff --git a/Marlin/Marlin.ino b/Marlin/Marlin.ino
index 79c934b..3a1285e 100644
--- a/Marlin/Marlin.ino
+++ b/Marlin/Marlin.ino
@@ -1,3 +1,4 @@
+#include
I just tried almost everything I was thinking of and don't want to give up.
I bought new arduino mega - no change,
My test with swapping motor and step stick proves that step stick and motor is fine.
1. Do I need to change anything in config?
2. How to test that ramps is not faulty (for extruder motor)?
Thanks,
Marek
Edited 1 time(s). Last edit at 11/03/2014 06:26PM by fornve.
