[HELP] [3Drag] only y axis is able to move
Posted by Tintin
November 04, 2014 02:30PM
Hi, i am a new repraper. I recently assembled a 3drag printer and here i encountered a problem with controlling. On the repetier interface, i tried to manually control the device. It turns out that only the y axis home button is functional. Other motors are not locked. Extruder temperature is shown as 738.8 degree but not hot at all. Bed temperature is normal. I switched the connector of y axis to the other motors on the chip and relative motor is able to go home. So i guess most probably is the controlling problem. Does anyone know how should i solve the problem? Appreciate it a lot.
Edited 1 time(s). Last edit at 11/04/2014 02:51PM by Tintin.
Re: [HELP] [3Drag] only y axis is able to move
November 04, 2014 02:35PM
Fan works very well but bed is not heating.
Tintin
Hi, i am a now repraper. I recently assembled a 3drag printer and here i encountered a problem with controlling. On the repetier interface, i tried to manually control the device. It turns out that only the y axis home button is functional. Other motors are not locked. Extruder temperature is shown as 738.8 degree but not hot at all. Bed temperature is normal. I switched the connector of y axis to the other motors on the chip and relative motor is able to go home. So i guess most probably is the controlling problem. Does anyone know how should i solve the problem? Appreciate it a lot.
November 04, 2014 02:45PM
Further more i noticed that, once the y home button is pressed, the green LED on the chip is active and Y controller chip has a red button on. However if other instructions are given, instead of green but the red LED is on and the respected controller has no action.
November 04, 2014 03:07PM
Hi, I'm having difficulty understanding your problem.
The temperature being 738.8 degrees is absolutely wrong. Did you select the correct thermistor in your firmware settings?
I would suggest contacting the reseller of the printer first. Maybe they can help you. They might be able to tell you what thermistor the printer is using.
The other axis not moving might be a problem of the endstops not being connected correctly? It's a bit cryptic and I don't exactly understand what you mean with 'the green LED on the chip is active' etcetera. There are no chips with LED's on them afaik on a Ramps. Does the controller have buttons that light up when pressed/used?
http://www.marinusdebeer.nl/
November 04, 2014 03:14PM
Appreciate a lot for your answering.
As shown in the picture, there is a red light on the circuit. Once the motor moves, the light will be on. I have already contacted the dealer but they have not reply yet.
As for the thermistor, it is the one provided by the dealer.
Edited 1 time(s). Last edit at 11/04/2014 04:41PM by Tintin.
November 04, 2014 03:15PM
November 04, 2014 03:18PM
nil
Edited 1 time(s). Last edit at 11/04/2014 04:42PM by Tintin.
November 04, 2014 04:18PM
Okay, I suggest you wait for them to answer, I don't immediately recognize the board type you have so I can't help you. On the site it says it's a Sanguinololu 1.3a but it doesn't look like the Sanguinololu 1.3a I have?..
One more piece of advice, please try to put all your replies in one post, that makes it easier for others to read. If you want to add information to a post on a later time, you can edit your message and add information smiling smiley (instead of posting three replies).
November 05, 2014 07:17PM
The soldering on the pololo pins is dreadful, this is clear from the photo.
November 06, 2014 12:22PM
It looks like a wiring problem. Did you receive any response from them yet?
November 06, 2014 12:29PM
From what I understand from your description, it seems like there might be a wiring problem.
It happens to me too, they hook up to the wrong axis.
Wait and see what they have to say
Edited 1 time(s). Last edit at 11/06/2014 12:29PM by botfeeder.
BotFeeder - Professional Manufactured 3D Filament
November 07, 2014 06:46AM
The dealer replies, and i will send the circuit back to them for checking. Thanks for your answers.
Will update once new info received.
December 23, 2014 09:33AM
Hi all,
After the dealer replace my circuit board, everything works well this time. Appreciate for your helping. Merry Christmas.
