LM16UU on 5/8" rods? November 07, 2014 12:43PM |
Re: LM16UU on 5/8" rods? November 07, 2014 01:39PM |
I wouldn't. While the anodized aluminum surface may have a high hardness, it's not a very thick layer and constant back and forth movement I would fear would wear though it and once it's through, things only get worse. The slop also would be significant particularly for a CNC application.Quote
epicepee
I recently got a few 5/8" ground aluminum rods. (I also got some Igus bushings but they have quite a bit of play.) 5/8" linear bearings are pretty expensive, but LM16UUs are cheap. 5/8" is 15.88mm, is this close enough to work?
Also: the rods are anodized aluminum, and the bearings use hardened steel balls. Will this cause problems? I plan to build a light-duty CNC router.
Re: LM16UU on 5/8" rods? November 08, 2014 01:01AM |
Re: LM16UU on 5/8" rods? November 24, 2014 10:12AM |
Re: LM16UU on 5/8" rods? November 24, 2014 11:28AM |
Re: LM16UU on 5/8" rods? November 24, 2014 01:40PM |
Chrome alloy steel rods are usually better options then true stainless unless you're operating in a corrosive environment. The chrome alloy steel have a harder hardness. That being said, it depends also on how the rods are made whether they retain their full hardness or if working them has reduced it from what it was originally spec'ed.Quote
jamesdanielv
even better may be to use stainless steel rod
Re: LM16UU on 5/8" rods? November 24, 2014 03:50PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
