Far end, or distal extruder
Posted by Easy
November 10, 2014 11:49AM
I have just discovered far end, or distal extruders, where the extruder motor is remotely located and the filament is fed through a flexible tube to the extruder.
I like that system (on paper) but wonder how well it works compared to having the extruder feed motor directly incorporated into the extruder assembly.
Edited 1 time(s). Last edit at 11/10/2014 11:50AM by Easy.
Re: Far end, or distal extruder
November 10, 2014 12:01PM
Hi, do you mean 'Bowden' extruders, or maybe more like 'Flexidrive'?
Bowden has the drawback that it needs more retract since the tube makes the filament more 'flexible' as the tube always has to be slightly bigger than the filament there is a little space around it that causes this.
However I'm guessing you are talking about Flexidrive kind of solutions, of which I don't know anything! But here is the central topic for that: [forums.reprap.org]
Good luck!
http://www.marinusdebeer.nl/
November 12, 2014 03:20PM
Sounds like you're talking about a Bowden extruder. They do work, allowing Delta setups to reach the high speeds they're capable of. They do have drawbacks, though, and tend to produce blobs and strings.
