Has Someone Autocleaning Before Printing Starts?
Posted by Plasteroid
November 11, 2014 01:06PM
I have to extrude 5mm and take it off with pliers just before the printing starts. What comercial machines do to clean the nozzle at start? Has someone invented something automatic nozzle cleaning?
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
Re: Has Someone Autocleaning Before Printing Starts?
November 11, 2014 02:17PM
Usually I've seen the printer draw a line along one of the edges to clean anything that's oozed and/or prime the nozzle. Or print a skirt to do the same thing.
November 11, 2014 03:24PM
I've seen a video of a printer where the print bed moves to home and then it moves so far that the nozzle isn't above the bed anymore, then filament is extruded, and the bed moves back under the nozzle and moves to the printing area and starts printing. Because the nozzle hits the side of the bed while being perfectly leveled, the extruded material falls down the side of the print bed and the nozzle is under pressure with clean filament.
In this video you see it happen when the nozzle gets cleaned for the next printing color:
[www.youtube.com]
This is what I have also seen at the start of a print on another machine, but I can't find the video!
Enjoy smiling smiley
Edited 1 time(s). Last edit at 11/11/2014 03:26PM by Ohmarinus.
http://www.marinusdebeer.nl/
November 11, 2014 10:26PM
the hydraraptor by nophead had a wire brush to clean the nozzle..
November 11, 2014 11:10PM
Not a good idea. Ferrous material will destroy hot brass. Don't take a wire brush to a brass nozzle.
November 12, 2014 03:11AM
I use a steel wool pads that are used for cleaning copper plumbing tubes before soldering.
They are made of pretty fine steel wool and don't damage the nozzle.
All about delta 3d printers in one place [www.deltarap.org]
November 12, 2014 04:39AM
It could be then steel wool cleaning point somewhere near the edge (or some other material). A piece of G-code. Cleaning before start options should be integrated to Slic3r.
November 12, 2014 07:30AM
If you park the nozzle on the bed while it is warming up then it doesn't need to be cleaned. See [hydraraptor.blogspot.co.uk]
November 12, 2014 08:59AM
I just print a skirt. Easy to implement. Only down side is that is shrinks your build area by a tiny amount.
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
November 12, 2014 10:43AM
I usually use skirt around the print, but it doesn't help with oozed filament smudging around nozzle hanging there and messing with the print. Sometimes with luck the ooze drops and stays away, but not always. Perhaps easier with PLA, but for now I'm using ABS. I have to try if it is then so simple like homing Z (parking the nozzle) ? Almost against glass bed no oozing then.
