Arc mode? November 14, 2014 01:56PM |
Re: Arc mode? November 14, 2014 03:29PM |
void mc_arc(float *position, float *target, float *offset, uint8_t axis_0, uint8_t axis_1, uint8_t axis_linear, float feed_rate, float radius, uint8_t isclockwise, uint8_t extruder) { // int acceleration_manager_was_enabled = plan_is_acceleration_manager_enabled(); // plan_set_acceleration_manager_enabled(false); // disable acceleration management for the duration of the arc float center_axis0 = position[axis_0] + offset[axis_0]; float center_axis1 = position[axis_1] + offset[axis_1]; ...
Re: Arc mode? November 14, 2014 03:37PM |
Re: Arc mode? November 14, 2014 06:32PM |
Re: Arc mode? November 14, 2014 06:43PM |
Re: Arc mode? November 17, 2014 09:35AM |
Re: Arc mode? November 17, 2014 12:52PM |
