what are you trying to print, can you include gcode file as well as the firmware you are using, and possibly the stl file? also what slicer used.
also what happens if you print from a computer, do you have an error log?
and do this first, format the sd card, then place the file on it. try it again, does the print finish?
it can be a file card format issue, sdcard damage, firmware issue such as improper interrupt loop, power supply issue, gcode commands issue. the list is endless. does your machine still home after it pauses?
Edited 2 time(s). Last edit at 11/18/2014 06:15PM by jamesdanielv.
