Dual extruders on ramps 1.4 November 19, 2014 05:08PM |
Re: Dual extruders on ramps 1.4 November 19, 2014 05:48PM |
Re: Dual extruders on ramps 1.4 November 19, 2014 07:36PM |
Re: Dual extruders on ramps 1.4 August 09, 2016 11:18PM |
Re: Dual extruders on ramps 1.4 August 10, 2016 10:57AM |
Re: Dual extruders on ramps 1.4 August 20, 2016 11:27AM |
Re: Dual extruders on ramps 1.4 August 24, 2016 09:59PM |
Re: Dual extruders on ramps 1.4 September 07, 2016 08:56AM |
Re: Dual extruders on ramps 1.4 February 06, 2018 02:46AM |
DaGameFace
i will post if you really want, but the two main things are these lines:
\\these change your board to recognize it has two hotends and a heated bed rather than a hotend, a fan and a bed
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_RAMPS_14_EEB
\\simple stating you have two hooked up
#define EXTRUDERS 2
\\the distance between your two nozzles, in my case its 30 mm on the x axis, the first extruder is 0,0
#define HOTEND_OFFSET_X {0.0, 30.00
and dont forget your thermister for your second hotend
Re: Dual extruders on ramps 1.4 February 06, 2018 06:22AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Dual extruders on ramps 1.4 February 06, 2018 07:47AM |
MagoKimbra
Hi, I put four extruders with ramps 1.4 without adding steppers. With my marlin and a card to 8 relays can control up to four extruders with only two drivers.
Otherwise you can mount another external driver taking three free pins to control it.
