Hot End Cooling with Heated Chamber November 20, 2014 12:36PM |
Re: Hot End Cooling with Heated Chamber November 20, 2014 01:38PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Hot End Cooling with Heated Chamber November 20, 2014 02:05PM |
Re: Hot End Cooling with Heated Chamber November 20, 2014 02:26PM |
Re: Hot End Cooling with Heated Chamber November 20, 2014 04:25PM |
Re: Hot End Cooling with Heated Chamber November 20, 2014 10:14PM |
Re: Hot End Cooling with Heated Chamber November 20, 2014 11:18PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 01:20AM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 09:48AM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 01:15PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 01:22PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 01:24PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 01:26PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 03:07PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 05:02PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 05:32PM |
Paul Wanamaker
Right now I am only controlling the heat of the build plate, although I do have hardware thermostats on both the heated bed and in the chamber to protect against serious over temp.
I do plan on adding a thermistor for the chamber.There are extra thermistor inputs on my Rumba (although I plan on replacing that board with a Smoothie).
I do not know yet if my firmware (Repetier) can manage chamber temp. That would be the simplest.
It would be simple enough to program a separate Arduino to read the thermistor and have it do something if the temp goes over say 65C.
This is sparking all kinds of ideas. I like the idea of offloading it, then there can be a separate readout of the chamber temp, and an indication of what steps are being taken. It could turn off the heated bed with a relay, adjust the speed of an exhaust fan, etc.
Hmmm, more interesting things to think about.
Re: Hot End Cooling with Heated Chamber November 21, 2014 06:07PM |
Re: Hot End Cooling with Heated Chamber November 21, 2014 10:12PM |
Re: Hot End Cooling with Heated Chamber November 22, 2014 12:05AM |
Re: Hot End Cooling with Heated Chamber November 24, 2014 11:47PM |
Paul Wanamaker
I like it.
Thanks for sharing the link.
Re: Hot End Cooling with Heated Chamber November 25, 2014 12:27AM |
Re: Hot End Cooling with Heated Chamber November 25, 2014 12:33AM |
Re: Hot End Cooling with Heated Chamber November 30, 2014 06:42AM |
Paul Wanamaker
Re: Hot End Cooling with Heated Chamber November 30, 2014 02:54PM |
Re: Hot End Cooling with Heated Chamber November 30, 2014 03:00PM |
Re: Hot End Cooling with Heated Chamber November 30, 2014 05:17PM |
Re: Hot End Cooling with Heated Chamber November 30, 2014 05:25PM |
