I've read about 10 different guides on stepper motors, and can't quite find the answer to this question.
Why exactly would a stepper motor have high resistance in the coils? Like these ones that I'm having problems with, which have about 20 ohms of resistance in the coils. I realize there are other factors at play like inductance, which contribute to overall impedence, but it just seems like you would want your copper coils to have as low of resistance as possible right?
Isn't having higher resistance just going to contribute to excessive heat, and thus be less efficient due to heat losses, as well as require much higher voltage to drive it just to overcome the resistance? I also don't quite understand how the manufacturer is even able to get a copper coil up to such a high resistance, unless it is extremely fine gauge and very long wire, or else if they add some resistors in there or something.
Alternately, my other stepper motors have around 2.2 ohms per coil, and I don't seem to be having any problems with them.
Edited 1 time(s). Last edit at 11/20/2014 04:17PM by scubaguy.
