Hardware for 24V 2.5A Stepper Motors November 22, 2014 03:43PM |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 04:20PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 04:26PM |
VDX
... have you according drivers for your steppers?
I'm driving steppers with an Arduino, powered with 12V (internal 5V) while the drivers+steppers are powered with 325V from their own net-plug PSU ...
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 04:52PM |
Admin Registered: 11 years ago Posts: 3,096 |
Specifications
Microcontroller: Atmega2560-16AU
Operating Voltage Electronics:5V
Operating Voltage High:12-24V (15A heated bed, 7A electronics)
DC Current per I/O Pin:40mA
Clock Speed:16Mhz
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 06:45PM |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 06:48PM |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 07:02PM |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 10:21PM |
Re: Hardware for 24V 2.5A Stepper Motors November 22, 2014 10:35PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 12:15AM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 12:25AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 03:47AM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 04:37AM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 11:12AM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 03:26PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 04:53PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 05:02PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 05:18PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 05:23PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 05:33PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 05:41PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 08:20PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 09:21PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 09:34PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 10:17PM |
george4657
Steppers work on magnetic force from coils of wire. If you feed 3.6 volts at 2.4 amps to the motor it would have full holding power.
To step the motor you reverse the direction of current in the coils. At 3.6 volts this would take a long time so motor would be very slow.
By using a higher voltage the current can be changed quicker and the motor can run much faster. The higher the voltage the faster the maximum speed is. The job of the driver circuit is to stop the current as soon as it hits the maximum allowed , 2.43 amps in your case.
The coil will release its stored current over time and the controler will refresh it to keep the average at the maximum. There used to be a rule of thumb of 20 times stepper voltage for the power supply maximum.
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 11:07PM |
Re: Hardware for 24V 2.5A Stepper Motors November 23, 2014 11:42PM |
Re: Hardware for 24V 2.5A Stepper Motors November 24, 2014 10:11PM |
Re: Hardware for 24V 2.5A Stepper Motors November 25, 2014 12:29AM |
Re: Hardware for 24V 2.5A Stepper Motors November 30, 2014 06:37AM |
