Suggestions for Improving the RepRap Wiki November 29, 2014 12:25AM |
Admin Registered: 15 years ago Posts: 730 |
Re: Suggestions for Improving the RepRap Wiki November 29, 2014 03:06AM |
Admin Registered: 13 years ago Posts: 1,063 |
MattMoses
Hi Everyone, this thread is for discussing ways to improve the RepRap Wiki. It continues a conversation started here.
Do you use the RepRap Wiki? Why or why not? Do you have any ideas for improving it?
Here are things I sometimes see people complain about:
Personally, I think many of the Wiki's problems would improve if there were simply more people making meaningful edits - improving organization, removing out-dated material, merging duplicated information, and so on. Almost anyone who reads this forum is qualified to do such work. You don't need to be an expert or even own a working printer (although that certainly helps!) to contribute to the wiki.
- Information is hard to find
- Information is out of date
- There are too many links to commercial sites that add nothing of value to the wiki.
What does everyone else think?
Re: Suggestions for Improving the RepRap Wiki November 29, 2014 10:15AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Suggestions for Improving the RepRap Wiki December 01, 2014 09:31PM |
Re: Suggestions for Improving the RepRap Wiki December 01, 2014 10:59PM |
Re: Suggestions for Improving the RepRap Wiki December 02, 2014 01:43AM |
Mutley3D
Perhaps what the Wiki and RepRap needs is a collective structure and decision making process. Albeit a very loose one.
1. It seems the guidelines would be a fairly intuitive set of statements that help to clarify a decision making process (accountable). You could probably create the guidelines I refer to simply by taking quotes from the above posts in this thread (ie couterfeits, dodgy sellers, ebay links etc). A most important statement would be about what to do with the multitude of 3D printer designs. Example: Does adding an LCD to an i3 make it an i3 Pro? No. It makes it an i3 with an LCD. Does a significant amount of rework and new parts, with leadscrews and released designs and sources make it an i3 Pro - much more likely Yes. (possibly a bad example but highlights the point).
2. Printer designs could go through a filtering/checking process. Is it a small modification? is it a full rework? Is it a significant upgrade? Going through a checking process it can potentially warrant a RepRap stamp of approval, or perhaps a graded stamp of approval that is indicative of what it represents. Achieving a stamp would be a distinguishing mark and may perhaps encourage designers to design something to achieve the stamp, and potentially put off the low grade "i did hardly any work to this design but ill rebrand it and call it my own" syndrome. But then it begs the question, is it a design that achieves the stamp, or the designer/supplier?
3. Things like cheap clones and other contentious items would then naturally fall into place, or off the wiki
4. RepRap potentialy can gain some outwardly visible cohesiveness in terms of self organsiation and become perhaps a better sum of parts as a whole.
5. If it achieves a "stamp" or some other indication (by way or prescence on the wiki under said guidelines) then it can be taken as safe that it stems from and is part of the RepRap philosophy and meets the criteria that this philosophy stands by.
As with all collective groups, the democratic process of instigating such an approach is often the biggest and hardest step to achieve in the very first instance.
Possibly it would be a step too far? Possibly such an appproach would be unworkable. Maybe just continue on the good judgement and initiative of the experienced and capable admins
Re: Suggestions for Improving the RepRap Wiki December 05, 2014 12:43AM |
thejollygrimreaper
the cartesio this one is Attribution - Non Comercial - ShareAlike , as far as i can see there is no sources and the external link just takes you to their webshop
thejollygrimreaper
however only stl files are available no actual sources
Re: Suggestions for Improving the RepRap Wiki December 05, 2014 12:52AM |
NormandC
thejollygrimreaper
Not defending this printer nor discussing about the license issue, but I'm pointing out the sources do seem to be available, although it takes a few clicks and brings to the builder's own wiki. [mauk.cc]
thejollygrimreaper
Agreed, this is always annoying.
Also, RepRap variations should not be on this page. I count no less than 10 Prusa i3 variants, and the original is not even listed! This is ridiculous, all those copies would not exist without the original. They should only be linked from the original i3 page IMHO.
Re: Suggestions for Improving the RepRap Wiki December 05, 2014 09:14PM |
thejollygrimreaper
all i can find on their wiki is the stl files, no sources that are obvious there,
Re: Suggestions for Improving the RepRap Wiki December 06, 2014 03:15AM |
vegasloki
thejollygrimreaper
No sources for the STLs doesn't meet the OSHWA guidelines (which aren't a license) but those aren't required under CC. CC dictates use and not deliverables. It's a bummer but it doesn't contradict the terms of the license.
There are variants because many devs don't iterate past a rev or two. For example Prusa. Builds on single plate i3s aren't near as common as a Rework. The Rework is the standard i3 build now, at least in North America.
What/who is the Wiki for? There doesn't seem to be a consensus. You guys are focusing on things like license, source, policing vendors and looking to enforce your version of what licensing means, but is that how people really use the Wiki and the kind of information for which they are looking? I use it a ton but don't contribute because there is no structure or any defined standards. For example I've got a Smartrap build doc that is more current and I think easier to follow than the one the dev posted. But I'm not going to post over his work to do it. Posting in addition would be too confusing for many. As he is the dev, I don't think that is respectful. However I would submit a pull request but that mechanism is not available. Some may like his better, some mine and some will like another doc altogether. Who decides which is represented in the Wiki?
What I do when referencing the Wiki for others is to give them specific pages, not general terms or info. For example the beginner page, the Smartrap page, the Rework page, RAMPS page or whatever specific resource they need. Not only is there so much info there, many (perhaps most) beginners are overloaded and/or may not know what is what. I see that a bunch.
Wikipedia works in part because it's a general resource that covers a wide variety of subjects. Here it's a specific resource for a specific topic. Wide range editing isn't going to be as effective here.
A couple other random thoughts...
What is the definition when you guys use the term counterfeit? Is a clone or compatible part/assembly counterfeit? How would you define it?
Commercial links... Don't allow them. Period. I see this as an information resource, not a marketing or sourcing tool. Perhaps link to the original dev's site but as noted on other posts, pages of links are difficult to manage, easily exploited by those less scrupulous and in general don't offer any value to the resource.
Re: Suggestions for Improving the RepRap Wiki December 06, 2014 07:45AM |
vegasloki
vegasloki
vegasloki
Re: Suggestions for Improving the RepRap Wiki December 06, 2014 09:58AM |
Re: Suggestions for Improving the RepRap Wiki December 09, 2014 03:39PM |
Re: Suggestions for Improving the RepRap Wiki December 10, 2014 04:51PM |
Re: Suggestions for Improving the RepRap Wiki December 11, 2014 08:55AM |
tobben
I suggest we spit in some dollars to pay for better hardware it can run on.
Re: Suggestions for Improving the RepRap Wiki December 11, 2014 04:14PM |
Re: Suggestions for Improving the RepRap Wiki December 11, 2014 04:15PM |
Re: Suggestions for Improving the RepRap Wiki December 11, 2014 06:08PM |
Re: Suggestions for Improving the RepRap Wiki December 11, 2014 09:49PM |
Re: Suggestions for Improving the RepRap Wiki December 12, 2014 07:48AM |
tobben
After that follows a list of languages and some navigation-links. When pressing one of these navigation links, they disappear.
Re: Suggestions for Improving the RepRap Wiki December 12, 2014 08:01AM |
Admin Registered: 18 years ago Posts: 14,162 |
Traumflug
I just removed the page protection, so this warning no longer appears.
Re: Suggestions for Improving the RepRap Wiki December 12, 2014 09:17AM |
VDX
... IIRC the page-protection was set by Adrian after some vendors start to fill the starting/entry pages with their links
Re: Suggestions for Improving the RepRap Wiki December 13, 2014 05:53AM |
Yes, it looks much better now, nice work!Quote
Traumflug
You mean these linked pages don't share the same headers? I agree, these pages should do so.
I agree. I put the new frame categories in the "maybe later"-drawer. I would like to know your opinion on my norms-post above.Quote
Vegasloki
The issue is in the structure of the information and the consistency of that information.
Re: Suggestions for Improving the RepRap Wiki December 13, 2014 06:18AM |
tobben
I'll be happy to start working if we just establish socially agreed upon "best practices"/norms.
Re: Suggestions for Improving the RepRap Wiki December 13, 2014 02:34PM |
Traumflug
Forget about some sort of "social agreement" in advance. Typically tedious discussions, zero results. Just go ahead and set your marks. Others will follow magically.
Re: Suggestions for Improving the RepRap Wiki December 14, 2014 09:39AM |
tobben
I have experienced the kind of magic you are talking about fail dramatically too many times. Do you have experience of the contrary?
tobben
Would you follow the "Table of Contents at the top"-norm if I imposed it, @Traumflug? I would like to contribute something that you and the rest of the Community actually wants...
Re: Suggestions for Improving the RepRap Wiki December 14, 2014 10:25AM |
People that don't care about organization and don't feel any responsibility for keeping things tidy will always show up when there is universal access. (I'm not against free editing access, but things like floods of commercial links happen.) If the ones tidying up give up, or if they don't agree on what is "tidy", then the magic fails. This has happened to various labs and student organizations that I have been a member/creator/destroyer of.Quote
Traumflug
Failing which way?
Ok. I consider it untidy.Quote
Traumflug
For table of contents across several pages, headers at the top are just fine.
Re: Suggestions for Improving the RepRap Wiki December 14, 2014 11:09AM |
tobben
tobbenOk. I consider it untidy.Quote
Traumflug
Re: Suggestions for Improving the RepRap Wiki December 14, 2014 01:38PM |
tobben
Traumflug
Failing which way?
Traumflug
Nice work on btw! (looking at changes log for 14 dec) I have more to say about the front page, but I just found out about the discussions tab, and suppose it belongs there.
Cheers!
Re: Suggestions for Improving the RepRap Wiki December 14, 2014 06:34PM |
