All Metal Hot End jamming
Posted by jhondon
December 02, 2014 02:26PM
I'm using an all metal hotend in my prusa i3, it has been working nicely for a few months, but now sometimes the extruder idler makes a tic sound and the extruder stops extruding, the filament gets jammed inside the hotend making it impossible to pull it out or push it further into the nozzle. I tried cleaning the nozzle and heat break using gas welding flame, but despite being cleaned twice, it still gets jammed. has anyone experienced the same? any ideas on what might be the cause? any help is appreciated,
thanks in advance
Re: All Metal Hot End jamming
December 02, 2014 03:01PM
Which hot end was it exactly? Are you sure it did not have a PTFE sleeve in it?
December 02, 2014 04:57PM
Filament can get stuck in the cold break if you're printing with PLA and heat creeps up the cold cold break toward the cold end of the extruder. Check to make sure the fan on the cold end is operating OK and make sure you run the fan for a while after finishing a print, to allow the hot end to cool properly without heat creep.
[3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
December 02, 2014 11:38PM
Damp some filament in Olive oil and run it through the hot end, then run a clean one. Be sure your fan is working an on all the time.
December 11, 2014 03:17AM
Had this exact same thing happen on one of the all metal hot ends we tested.
We never tried oil, but we always used a fan. Leaving it on after prints didn't help at all in our case.
December 11, 2014 10:17AM
The real reason for jamming in all metal hot ends with pla is due to the sharp heat break and retraction. At least I think so. With ABS its not such a problem simply due to the higher temperatures. At this point I think we need to take all we have learned and design a proper all metal hot end that can be used passively for any material.
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
December 13, 2014 01:11AM
I would say the Prometheus hotend fits that bill perfectly.
December 13, 2014 02:39PM
I have to agree with Prometheus being an ideal high temp hotend, and possibly the best. The barrel is a one-piece polished design which eliminates joints that can cause binding, sticking, etc.
I have mine configured with a 2mm long transition zone and a nut on each side of the heater block and I get excellent results with a bowden setup and PLA. No need to using the oil trick and it works well the cheapest and premium priced PLA's. ABS is even easier. With minimal retraction and wipe settings, I have zero stringing.
Another advantage of the Prometheus is strength. I've see too many other high temp hotends with bent or broken heat breaks. The one-piece Prometheus is much stronger.
September 10, 2015 09:10PM
Came across this thread while researching some jamming issues on one of the new-fangled all metal hotends.
I honestly don't understand this constant cyclic need to reinvent the wheel over and over again.
Arcol.hu hotends have been extruding PLA, ABS and whatever else you want, without jams and without hotend fans for years.
The draft from the print fan is enough to keep them happy.
All the while being shorter and more compact, with less parts, than any of the newcomers.
September 11, 2015 11:16AM
Hello,
Genuine J-Head hot-ends have worked fine with PLA for years, as well. However, china has taken over the J-Head market and produce poor quailty knock-offs. So, you have to shop around for the few vendors that still sell the real thing.
Best Regards,
Brian
Nio
April 19, 2016 08:32AM
I do need a fan for my arcol hi v4 with abs. i starts printing fine, but constantly jammes without a fan after a few layers.,maybe i print too slow,,or the temperature of hotend or extruder is too high. or its my x carriage on a classic sells reprap. or the all metal extruder
with the fan i am totally fine
i dont have a fan directed to the print. this does not work with me for abs on glass.
Edited 1 time(s). Last edit at 04/19/2016 08:34AM by Nio.
April 19, 2016 05:30PM
I haven't tried it yet but I did buy some to try next time I rebuild my hot end - tungsten disulphide. It's a coating which apparently nothing ever sticks to including molten plastic. Quite toxic by all accounts but I'm not intending to eat it.
Simon Khoury
Published:Inventions
May 17, 2016 10:43AM
This has been ruining my life. I just drilled a hole from the top through the throat and ran PTFE all the way down to the nozzle. Runs smooth as silk now. I am going to go back and troubleshoot this to get the all metal one working. Any luck for you?
May 17, 2016 12:39PM
I've had no jams with the tungsten disulphide. With all metal polishing seems to be very important, drilling is going to leave a very rough surface, there are lots of instuctable-type things out these about how to polish inside hot end throats.
Simon Khoury
May 24, 2016 09:59AM
I run 1.75 filament of PLA in my 3 mm bowden printer, and works very well. Nothing as smooth and thermal insulator as air.
Not useful for 1.75 mm printers.
