Hola Reprap forum!
We are just about to launch a new feature (in 2-3 days) on the
AstroPrint Cloud Slicer in which users can choose to use
optimized slic3r or cura settings for their printer. In the long run, we want this to be "manufacturer suggested" slicer settings, however, in the short run, we can take slicer settings from experts in the industry, even if they are not the manufacturer.
What we need is to source optimized .ini files from people that would consider themselves experts with specific printer models. Please see below for exactly what we need.
BTW, this is all free, we are not charging to use Slic3r/Cura! Slic3r and Cura Engine have been untouched (in relation to code), but have been put on a cloud server. We will maintain the most up to date stable version as new versions come out. We're all-good in relation to licensing, I promise!
Here's how it works for the end user:
- "Add a printer" to my account: User selects a manufacturer/printer from a list, or adds a custom configuration.
- If they select a manufacturer/printer from our list: The printer settings, associated materials, and all other settings are imported into their account. Their default slicer will be set to whichever one has been chosen by the manufacturer.
- Whenever they slice, these settings will be used (unless they change them manually of course).
- If the manufacturer changes those settings in the future (to further optimize) they will be updated in real time for each person using that printer. Of course, if the settings have been altered, they are then considered custom and will not be updated.
Here's how it works for manufacturers/admins:
- Add a printer and associated materials to the system. Set which slicer you prefer used for that printer.
- Update printer and material slicer settings. This can be done by uploading .ini files, or by changing settings manually.
- Hit Publish.
- Now anytime someone chooses that printer, they will get your slicer settings by default.
- If you are not the manufacturer, but you are an expert with a specific printer, you can send us the .ini files and we can input the printer in the system. When the manufacturer chooses to "claim" the account, they can, and will take over the settings. This is very similar to how yelp let's you put in information about a business, but then that business can "claim" the account and take it over if they wish.
Here's what we need:
For Marlin firmware based printers, we need:
- an .ini file for: low quality (fast, low infill, etc), medium quality, and high quality. (Slic3r, Cura, or both)
- an .ini file for changes that would occur on top of those settings for each Material for that printer. For example, we need another low, medium, and high quality related .ini file for PLA, and another set for ABS, etc.
- So, to input a printer with PLA and ABS we would need 9 ini files (3 for the printer, 3 for PLA, and 3 for ABS).
Here's how the end logic works when a slice occurs:
- We start with the AstroPrint default slicer settings.
- Any settings in the Printer .ini file (from the manufacturer) override the AstroPrint settings.
- Any settings in the Material .ini file override the Printer settings and AstroPrint settings.
- Any personal customizations to settings, by the end user, override everything.
So, please contact us through our
support desk if you are:
- A marlin based 3D printer manufacturer that wishes to be part of this program. (BTW, it's all free.)
- An expert with slicing settings for a specific printer (it still needs to be Marlin based though). (We can only have 1 expert per printer, otherwise it's just too complicated)
Or, please post any and all questions here in this forum.
Thanks,
~Drew
AstroPrint.com
Edited 1 time(s). Last edit at 12/12/2014 11:06PM by DTaylor.
