Hello,
I have a printer Prusa.
I made the change of the filament 3 mm by 1.75 mm but I have a problem I can not solve, the model have waves in the Z axis. The layers more "extrude" the other layers. As shown in the picture attached.
I use the Cura as slicing and settings are as follows:
layer_height = 0.075
wall_thickness = 1.2
retraction_enable = True
solid_layer_thickness = 0.6
fill_density = 30
nozzle_size = 0.4
print_speed = 10
print_temperature = 230
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 110
support = None
platform_adhesion = None
support_dual_extrusion = False
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = 100
retraction_speed = 40
retraction_amount = 5.0
retraction_dual_amount = 16.5
retraction_min_travel = 1
retraction_combing = True
retraction_minimal_extrusion = 0.01
retraction_hop = 0.0
bottom_thickness = 0.0
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 100
bottom_layer_speed = 10
infill_speed = 30
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 0
fan_enabled = True
skirt_line_count = 3
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Grid
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 15
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
raft_airgap = 0.22
raft_surface_layers = 2
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
By the printer settings I use:
Acceleration: 200 in the X and Y and Z in 100
Steps / mm: 95
Jerk: 16.0
Z-Jerk: 0.2
Sorry my bad english
Klaus Maximilian
