Re: Enclosure math- why they're so important and how to make one. April 07, 2015 11:59PM |
No. The formula is for the Δt...I just happened to put what the Δt was and not (80 degrees C - 20 degrees C). The original example was 20 degree C ambient air temperature and a theoretical 80 degree C build chamber. That's 60 degrees C. If it was in K, it would 293.15 K ambient and 353.15 K build chamber. And look, it's still a difference of 60 just in Kelvin. Kevin...degrees C...when talking about a Δt it doesn't matter between the two.Quote
Djkingsley
60 degrees Kelvin is -213.15 degrees Celsius. I believe you meant to use 333.15 degrees Kelvin which would give you 3.5 W/m^2K * 1m * 333.15 K = 1166 W
Re: Enclosure math- why they're so important and how to make one. April 08, 2015 11:12AM |
Re: Enclosure math- why they're so important and how to make one. April 08, 2015 11:41AM |
Re: Enclosure math- why they're so important and how to make one. April 08, 2015 10:31PM |
Re: Enclosure math- why they're so important and how to make one. April 09, 2015 02:03AM |
Re: Enclosure math- why they're so important and how to make one. April 09, 2015 12:10PM |
cdru
I know it's an older post, but your numbers are incorrect for what you're trying to compute as you are confusing thermal conductivity with heat transfer coefficient.
Thermal conductivity is how well heat flows within a material. For our heater blocks, we want heat to flow very well so that it's even and no hot spots right next to the heater but not on the far side of the melt chamber. For this, we choose aluminum or brass because they have a "k value" in the hundreds of W/(m K). But because the thermal conductivity is so good, this is why all metal hot ends heat breaks aren't made of aluminum...it would wick all that heat away up into the cooling fins defeating the purpose of a heat break. So instead they are made of stainless steel which has a k value of around 16 W/(m K). Polycarbonate has a k value of .19 W/(m K). It would make a excellent material for a heat break as it resists the transfer of heat...if only it could withstand the heat (it can't). In terms of your enclosure, 1900 Watts is the rate of heat transfer WITHIN THE POLYCARBONATE if you had the inside surface at 80 degrees Celsius and the outside at 20 degrees Celsius. Slowly over time though the outside surface would raise in temperature as more heat from the inside was generated. That is then where the heat transfer coefficient comes into play...
The heat transfer coefficient is basically how well the material gives off heat, usually in the form of convection between solids and a fluid or gas. This multiwall polycarbonate sheet like was shown above has a coefficient of 3.7W/(m² K). I found a few solid 6mm sheets that had a coefficient of 3.5W/(m² K). A box with a surface area of 1 meter made of solid polycarbonate 6mm thick would lose 3.5 W/(m² K) * 1m² * 60 Kelvin = 210 Watts, NOT 1900 Watts.
