AWorldnet A600 Not Working January 07, 2015 03:35PM |
Re: AWorldnet A600 Not Working January 08, 2015 10:04AM |
Re: AWorldnet A600 Not Working January 12, 2015 03:17AM |
Re: AWorldnet A600 Not Working January 12, 2015 03:41AM |
Re: AWorldnet A600 Not Working January 12, 2015 05:13AM |
Re: AWorldnet A600 Not Working January 12, 2015 05:36AM |
Re: AWorldnet A600 Not Working January 13, 2015 03:20AM |
Re: AWorldnet A600 Not Working January 13, 2015 06:21AM |
Re: AWorldnet A600 Not Working January 13, 2015 06:31AM |
Re: AWorldnet A600 Not Working January 13, 2015 07:36AM |
Re: AWorldnet A600 Not Working January 13, 2015 07:51AM |
Re: AWorldnet A600 Not Working January 13, 2015 09:25AM |
Re: AWorldnet A600 Not Working January 13, 2015 09:40AM |
Re: AWorldnet A600 Not Working January 13, 2015 10:01AM |
Re: AWorldnet A600 Not Working January 14, 2015 06:14AM |
Re: AWorldnet A600 Not Working January 14, 2015 06:40AM |
Re: AWorldnet A600 Not Working January 14, 2015 07:50AM |
Re: AWorldnet A600 Not Working January 15, 2015 03:59PM |
Re: AWorldnet A600 Not Working January 19, 2015 07:02AM |
. Im learning to work around it. i found that if i leave extruder head near heatbed when worming up the heatbed the fan on extruder head ( the one on the heatsink) cools the heatbed so it can't reach more than 86C and im using new abs that needs 96c (found by trial and error). So i have to retract the z axis to minimum of 10cm above the heatbed. now am planing to rearange the extruder head to be more sturdy because it shakes a litlt bit when i start to to wobble it with hand. |
Re: AWorldnet A600 Not Working January 19, 2015 07:07AM |
Re: AWorldnet A600 Not Working January 19, 2015 10:05AM |
Re: AWorldnet A600 Not Working January 25, 2015 10:41AM |
Re: AWorldnet A600 Not Working January 28, 2015 04:49PM |
Re: AWorldnet A600 Not Working January 29, 2015 04:27AM |
You should at last reach the glass temperature of the plastic with the heatbed. For ABS it's around 105°C. If you set your heatbed under 105°C it's not realy effective.Quote
darac_komarac
im using abs
it was 230 for nozzle, and 80 for heatbed
Re: AWorldnet A600 Not Working February 02, 2015 06:02AM |
Zavashier
darac_komarac
im using abs
Re: AWorldnet A600 Not Working February 09, 2015 04:49PM |
Re: AWorldnet A600 Not Working February 09, 2015 05:37PM |
Re: AWorldnet A600 Not Working February 09, 2015 05:39PM |
Re: AWorldnet A600 Not Working February 09, 2015 06:25PM |
darac_komarac
now i have problems with extruder.... it seem that the gear is hobbing the filament whitch results in stoping the extruzionleaving gaps in print. i tried everything i could ( cleaning the nozzle, c leaning the hotend, cleaning the extruder gear from hobbed filament, changing the temperature of hotend, tightening the gears vs extruder....). i even replaced the extruder...... nothing helped......
if i tighten the the filament too hard the motor start to skip ........
any thoughts?
thanks
