Re: AWorldnet A600 Not Working
March 05, 2015 09:51AM
Ok will start compiling it for you specifically you'll have to mess with the config.h for steps per mm
March 05, 2015 09:56AM
transmech
Will do later this week. Also do you have an lcd? Also what about the auto level hardware? If not I can send you the link to the thingiverse.com file for it. You wouldn't believe the difference it makes.
I'll take the link to the auto leveling thingiverse files.
March 06, 2015 07:47AM
Thanks man!
looling forward to it
March 06, 2015 10:51PM
Here it is All done with no auto bed leveling. Only works on Ramps with Arduino mega. Sorry guys with the Melzi board no luv for now.
[drive.google.com]
March 06, 2015 11:09PM
Sorry about that here is the thingiverse link.[www.thingiverse.com]
March 10, 2015 08:45AM
thank you very very much!!
i'll try to upload and start tweeking..... as soon as i solve this problem.... my exruder breaked....
[drive.google.com]
March 10, 2015 07:26PM
Sorry to hear that. I'm still trying to get mine completely dialed in. I'm thinking about changing to a bowden style xtruder with a different head.
March 11, 2015 09:04AM
i was soooooo pisted off with that but i managed to repair it and to buy some extruder time to print another one.... i found on marlin board pot to increase the power for extruder so now it doesnt missing steps any more..... at least that
March 11, 2015 09:09AM
i have e3d extruder bowden tipe and i even printed out the mount for it. if you want i can send it to you. it fits on aworldnet carriage...
i have to put it on again, now when my extruder motor doesn't skip steps any more
March 11, 2015 02:39PM
I would very much appreciate that. I want to decrease the mass of the x carrier. Thanks!
October 11, 2015 11:13AM
transmech
[drive.google.com]
hi, i use your mod firmware. but i having some issue like my z home not responding and x and y stop at halfway when i try to push to 200mm ???? . the z axis goes up and not down, any idea what could be ??? thank you for any input.
October 16, 2015 07:03PM
hi, by any chance can you spare the setting for the a600 firmware, my board got bad and i can't find the original firmware with the right setting. thank you.
October 18, 2015 10:37AM
thx for the input .
October 18, 2015 10:44AM
magnetos
thx for the input .
for some reason the step/mm are complete diffirent from original setting that you have on repitier firmware.
i try with repitier firmware and the printer axis stop at middle of the axis at 200mm but if i use my setting goes to the other end the axis .. lets say the real 200mm
here my setting for marlin 1.0.2.
define DEFAULT_AXIS_STEPS_PER_UNIT {204.78,204.78,684,760*1.1} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {200, 200, 4, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1000,1000,100,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
not sure if its 100% right step/mm , will need to adjust as soon i start to print my first cube 10x10x10 from there i will. i try the calculator (step/mm) that came with repitier-host and i try the i-prusa calculator but that both give me wrong steps/mm (80 to 100) ??? what am i doing wrong here ???
