Mobile drill press?
January 11, 2015 12:26PM
I keep looking for a device to attach to a power drill which makes it operate a bit like a router, i.e. up and down perpendicular to the surface being drilled. I can't find anything, but it could be another case of not knowing what it's called.
Any ideas?
Re: Mobile drill press?
January 11, 2015 01:53PM
Something like this? You should search for Hand Drill Press Stand
[www.amazon.com]
[www.amazon.com]
Thanks Mike
Edited 1 time(s). Last edit at 01/11/2015 01:59PM by Miertam.
January 11, 2015 02:49PM
Sort of but more mobile. I actually considered using one of those, because if it's not bolted to a bench it sort of does what I want, but it's a bit difficult to aim.
So imagine you've got a bit of wood say 24inches by 600mm by a thumb thick. You want to make a hole in the very center. You can't use a normal drill press because of the pole, so something like a router would give you a nice 90degree hole, but they can be a bit awkward to make holes with as they like to drift. Sort of see what I'm after?
January 11, 2015 06:22PM
January 12, 2015 12:57AM
You could make a drill guide from a block of wood, say 4" square and 1" thick. Put it on your drill press table to get an accurate hole drilled through the block then use this as a guide on your job.
_______________________________________
Waitaki 3D Printer
January 12, 2015 04:39PM
