Alibre Design and Reprap Isaac and milling parts May 15, 2010 01:49PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 02:19PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 02:34PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 02:48PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 03:08PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 03:16PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 04:19PM |
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 05:53PM |
KeithSloan
Could you not modify the EMC extension to just use the Extruder Controller for controlling the heater on/off/temp. i.e. ignore motor control. When it sends it a command to set the temperature via the serial link does it then wait for a reply via the serial link. Same question with heater on/off
Re: Alibre Design and Reprap Isaac and milling parts May 15, 2010 06:07PM |
I also came across references to a free package called Alibre Design Xpress. Most web references pointed back to the 30 day trial version of Alibre
I just checked the isaac files and although they were created with Alibre they are actually STEP files rather than native Alibre. Whoops
. The native Alibre version is split into a large number of files; the (enhanced) Step export is a single file that is importable by both Alibre and other CADs. The enhancement: Alibre stuffs all of its proprietary stuff into the Step export. When you import the Step back into Alibre, it converts it back into the large set of native Alibre files with everything intact.|
Re: Alibre Design and Reprap Isaac and milling parts May 16, 2010 01:37AM |
Re: Alibre Design and Reprap Isaac and milling parts May 16, 2010 02:27PM |
Re: Alibre Design and Reprap Isaac and milling parts May 16, 2010 04:49PM |
Re: Alibre Design and Reprap Isaac and milling parts May 17, 2010 08:54AM |
Re: Alibre Design and Reprap Isaac and milling parts May 17, 2010 11:34AM |
Re: Alibre Design and Reprap Isaac and milling parts May 17, 2010 04:57PM |
Re: Alibre Design and Reprap Isaac and milling parts May 18, 2010 02:59AM |
Re: Alibre Design and Reprap Isaac and milling parts May 18, 2010 03:53AM |
Re: Alibre Design and Reprap Isaac and milling parts May 18, 2010 04:00AM |
Re: Alibre Design and Reprap Isaac and milling parts May 20, 2010 08:31AM |
Re: Alibre Design and Reprap Isaac and milling parts May 21, 2010 01:05PM |
Re: Alibre Design and Reprap Isaac and milling parts May 28, 2010 07:36PM |
Re: Alibre Design and Reprap Isaac and milling parts June 12, 2010 09:48AM |
Re: Alibre Design and Reprap Isaac and milling parts June 12, 2010 03:02PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
