Filament slipping January 26, 2015 07:34AM |
Re: Filament slipping January 26, 2015 08:22AM |
Re: Filament slipping January 26, 2015 08:43AM |
Re: Filament slipping January 26, 2015 09:19AM |
Re: Filament slipping January 26, 2015 10:05AM |
Re: Filament slipping January 26, 2015 11:07AM |
Re: Filament slipping January 26, 2015 01:27PM |
Re: Filament slipping January 26, 2015 03:43PM |
Re: Filament slipping January 26, 2015 05:22PM |
I agree with prof braino, Check the hotend pushing the filament by hand. (245°C for ABS, 200°C for PLA) It should be as easy as inserting a knife into some butter. If it's not, take the hotend apart and check if it's in good shape and nothing obstruate the nozzle. With low quality nozzle/filament, sometimes some dust or metal chips lay into the nozzle.Quote
prof braino
How are you sure the hotend is not blocked? Can you push filament through the tube by hand to see it squirt out the nozzle? .
Re: Filament slipping January 26, 2015 05:24PM |
Re: Filament slipping January 28, 2015 12:34PM |
Re: Filament slipping January 28, 2015 12:56PM |
Capinho
I have changed the bearing, changed the gear, made temperature higher (230 degrees). Results are a bit better, but still pretty much the same issue.
here is a video
[onedrive.live.com]
Re: Filament slipping January 28, 2015 01:12PM |
Re: Filament slipping January 28, 2015 08:20PM |
Re: Filament slipping January 29, 2015 05:54AM |
Re: Filament slipping January 29, 2015 10:47AM |
