Windows 10 and Arduino problems
Posted by plankton
January 26, 2015 08:14AM
The latest preview build of Windows 10 (can't remember the release number, but it was released in the last few days) caused some very strange problems with my printer electronics (RAMPS and Arduino) which seem to be down to an issue with the USB serial driver. YMMV depending if the issue only affects specific USB hardware, but here's what happened in case anyone else hits the same problem.
I've been running the Windows 10 preview on my main PC (with a dual boot of Windows 7 to fall back on in case of problems), on Saturday night I downloaded the latest update without apparent problems. Sunday morning my printer froze 4 times during a simple 45 minute print (it resumed when I paused, and resumed from Pronterface), not knowing the cause I decided to give it a full electrical and mechanical service, after which I recalibrated my Z height and tried to update Marlin with the new Z height, but Marlin failed to load. The code compiled ok, but seemed to fail at the end of the upload with an "averdude checksum error", fortunately I have a spare Arduino here and testing on that gave the same error with Marlin (my version, or the default), but smaller sketches worked without problems. At that point I began to suspect the serial driver and double checked that the update hadn't changed any of the handshake settings (it hadn't, that I could see), then I tried Windows 7 and voila, problem gone.
Without spare hardware, and another version of Windows, this would have been devilish to troubleshoot, so hopefully this helps someone.
Tim
Printers:
Prusa i3 (plywood box frame)
RAMPS 1.4 and Arduino Mega
Mendel 90 (sturdy)
Smoothieware
My RepRap Blog
Re: Windows 10 and Arduino problems
January 26, 2015 07:33PM
I can confirm the same issue, the smaller sketching working, the checksum error and the pauses. My Windows 8 PC works fine. It also appears that a verification fail on reprogramming the RAMPS board from Windows 10 fails at the same location every time byte 0x2be2 although I doubt that will be similar to everyone. Earlier today I flashed the bootloader and everything with an AVRisp thinking that there was some issue with that only to later find out its only my Windows 10 Machine. I am glad to see someone else confirm it before I went crazy thinking it was a hardware issue on my PC.
January 27, 2015 10:06AM
I'm talking to Microsoft support about this, so I'll update here when there's a fix.
February 08, 2015 07:27PM
See this thread (I have same problem) [answers.microsoft.com]
February 08, 2015 07:49PM
Yes, that's the thread I started with MS.
February 10, 2015 08:18AM
Microsoft have advised they were able to reproduce the problem and diagnose the cause (they don't tell us what it was), the next Windows 10 update should have the fix.
February 12, 2015 08:05AM
fantastic, same here and I were thinking I had dead hardware, until I tried it in win7 too. in the original windows 10 build I could print OK but there may still have been some pauses, but in this build it is useless. hope the fix comes out soon.
February 13, 2015 11:30AM
A new arduino driver got installed with cura 15.9.... I bet its a driver issue. Worth a try.
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
February 14, 2015 11:24AM
Just tried to flash with new Cura driver same problem. It must be a com port issue with Windows 10 everything flashed fine with same Marlin build on windows 7. I guess we will have to wait for a new build of Windows 10 for a fix.
