Where to buy Reprap 150mm x 150mm Heatbed?
Posted by AlexV
January 31, 2015 05:03AM
Hi Everyone,
I am designing a Reprap that demands a 150mm x 150mm heat bed. The design, at the moment, has an aluminium bed with a silicone pad or kapton tape heater. Unfortunately, it seems that these two types of heater elements do not come in the size I require and I do not wish to leave the edges without direct heat.
Any ideas? I'm open to alternate solutions (ie. materials etc.) to building the bed/heatbed.
Alex V
Edited 2 time(s). Last edit at 01/31/2015 05:04AM by AlexV.
Re: Where to buy Reprap 150mm x 150mm Heatbed?
January 31, 2015 05:51AM
here is one : [www.aliexpress.com]
January 31, 2015 06:25AM
Make your own by the etching from FR4 copper clad glass fiber board. If the pattern is accurately scaled the resistance should remain the same - you will however have to do some checking on the true thickness of the copper on the FR4 that you get as this seems to be a bit variable. I have two variations on the design I use on Thingiverse at [www.thingiverse.com] and [www.thingiverse.com]
January 31, 2015 09:37AM
On how to calculate these copper tracks: [reprap.org]
On how to make a bed without that (a bit ugly, but working well): [reprap.org]
