Best material to reduce those pesky vibrations February 02, 2015 11:23AM |
Re: Best material to reduce those pesky vibrations February 02, 2015 01:22PM |
Re: Best material to reduce those pesky vibrations February 02, 2015 01:24PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Best material to reduce those pesky vibrations February 02, 2015 02:06PM |
Re: Best material to reduce those pesky vibrations February 02, 2015 03:32PM |
Re: Best material to reduce those pesky vibrations February 02, 2015 03:58PM |
Re: Best material to reduce those pesky vibrations February 02, 2015 06:14PM |
Re: Best material to reduce those pesky vibrations February 02, 2015 10:14PM |
Re: Best material to reduce those pesky vibrations February 03, 2015 12:08AM |
jtoombs
Also, I came across this design and was wondering if it could be applicable at the 3D printing scale.
Re: Best material to reduce those pesky vibrations February 03, 2015 09:54AM |
Re: Best material to reduce those pesky vibrations February 03, 2015 10:38AM |
Re: Best material to reduce those pesky vibrations February 03, 2015 04:36PM |
Re: Best material to reduce those pesky vibrations February 03, 2015 08:45PM |
Re: Best material to reduce those pesky vibrations February 04, 2015 01:19AM |
Re: Best material to reduce those pesky vibrations February 04, 2015 12:21PM |
Re: Best material to reduce those pesky vibrations February 04, 2015 12:31PM |
Re: Best material to reduce those pesky vibrations February 04, 2015 12:54PM |
jtoombs
Dentist, from your other posts I have seen around the forums you have leadscrews on all of axes, right? I hope this harmonic damper produces good results for your printer. It seems like it has good potential due to the similarities between your printer and CNC machines which this device is used on. Let me know what happens when you complete your tests. Unfortunately, my motors are not dual shafted. Not the optimal situation for a simple harmonic damper. I would still like to see your design if you don't mind posting it.
JTT
Re: Best material to reduce those pesky vibrations February 04, 2015 11:06PM |
Re: Best material to reduce those pesky vibrations February 04, 2015 11:29PM |
Re: Best material to reduce those pesky vibrations February 05, 2015 08:08AM |
the_digital_dentist
Those are essentially the same as the astrosyn dampers that don't help much at all.
Re: Best material to reduce those pesky vibrations February 09, 2015 10:57PM |
Re: Best material to reduce those pesky vibrations February 10, 2015 07:49AM |
Re: Best material to reduce those pesky vibrations February 10, 2015 08:31AM |
Re: Best material to reduce those pesky vibrations February 10, 2015 10:18AM |
Re: Best material to reduce those pesky vibrations February 10, 2015 09:56PM |
Re: Best material to reduce those pesky vibrations February 11, 2015 07:29AM |
Re: Best material to reduce those pesky vibrations February 25, 2015 03:01PM |
Re: Best material to reduce those pesky vibrations February 26, 2015 07:21AM |
Re: Best material to reduce those pesky vibrations February 26, 2015 11:41AM |
Re: Best material to reduce those pesky vibrations February 26, 2015 12:16PM |
