Open source licence, but no sources. February 04, 2015 11:30AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Open source licence, but no sources. February 04, 2015 01:23PM |
Admin Registered: 13 years ago Posts: 730 |
And yes, people here on the forum and wiki do not all agree with this definition. For example, some people agree with all of it except the "and sell" part.Quote
Open Source Hardware Association
Open source hardware is hardware whose design is made publicly available so that anyone can study, modify, distribute, make, and sell the design or hardware based on that design.
There are probably many RepRappers who could copy the design, but either way it is not really relevant. If he wants to call his design "open source" then the source should be open. How can that be hard to understand?Quote
Traumflug
He says sources would be pointless, because a RepRapper wouldn't be able to make a copy anyways...
Re: Open source licence, but no sources. February 04, 2015 02:15PM |
That's his prerogative to use CC-NC-*, but CC-NC-* is not open source. The first 3 questions on the FAQ here explain why. CC-NC-* is better than nothing, but it's not open. Open means anyone, regardless of commercial intent, can do what they want with it.Quote
Traumflug
he considers to comply with the CC-BY-NC-SA licence by just putting this licence onto the design.
So he's an arrogant ass too...Quote
I don't think that there is a problem leaving it, but having it clearly marked as not open source I think is legitimate thing to do. And if they can not or will not provide a "source" other than a PDF or images, then it's pointless to say it's open source.Quote
What do you think? Shall we draw a line here? Like keeping these tags despite the lamenting?
Re: Open source licence, but no sources. February 04, 2015 02:41PM |
The inclusion of "Non-Commercial" though can however pertain to more than just the manufacturing of the same or derivative design for a commercial gain. By tagging it as NC, you also violate #8 of the OSHWA definiton:Quote
MattMoses
8. No Discrimination Against Fields of Endeavor
The license must not restrict anyone from making use of the work (including manufactured hardware) in a specific field of endeavor. For example, it must not restrict the hardware from being used in a business, or from being used in nuclear research.
Re: Open source licence, but no sources. February 04, 2015 02:52PM |
Re: Open source licence, but no sources. February 04, 2015 03:19PM |
Re: Open source licence, but no sources. February 04, 2015 03:34PM |
Re: Open source licence, but no sources. February 04, 2015 04:51PM |
MattMoses
The other question (which we usually end up arguing about) is:
2. Is CC-NC-* license an open source license?
Based on many many many previous discussions about this on this forum, I am certain that no one here will be able to come to agreement on Question 2. Furthermore, it is kind of a pointless question anyway because CC licenses don't really have any legal meaning when it comes to a hardware design. Whenever this question comes up, people focus on it, argue about it, and nothing is ever resolved. For this reason, I think it is very good to have a non-controversial "lowest common denominator" compromise.
I think the compromise should work like this:
If there are not sufficient files to create a copy, then it gets the "not open source" tag.
If there *are* sufficient files to create a copy, but the license is some weird thing that people argue about (CC-NC-* or "permission needed" or "attribution requested" or whatever other weird, unfounded, unenforceable, no-legal-basis thing people like to slap on their hardware design), then it does *not* get the "not open source" tag. Because at least the files are available.
Re: Open source licence, but no sources. February 04, 2015 05:52PM |
cdru
I don't understand why such a concept suddenly becomes so difficult or hard once you talk about hardware.
cdru
If someone wants to keep their design protected and not make it truly Open Source, that's fine. They can use a CC-NC, closed source, or whatever they want. And I don't think we should automatically exclude or blackball them from ever being talked about on the Wiki.
cdru
But they shouldn't be rewarded with a I'm-an-Open-Source badge or label or any other type of indication when they are not. I do think hardware that does fit that definition should be marked as such, and celebrated as such for fitting in with the goal and origins of the RepRap Project.
Re: Open source licence, but no sources. February 05, 2015 06:20AM |
Re: Open source licence, but no sources. February 05, 2015 01:37PM |
Re: Open source licence, but no sources. February 05, 2015 03:48PM |
rmlrn
GPL already covered this issue..
Re: Open source licence, but no sources. February 05, 2015 04:00PM |
leadinglights
As far as providing the files the creator used, does that include all data sheets, working calculations etc.?
Re: Open source licence, but no sources. February 05, 2015 04:03PM |
leadinglights
Replying to rmlrn,
But only if the design is licensed under the GPL and not simply as "Open Source"
Re: Open source licence, but no sources. February 05, 2015 04:07PM |
Traumflug
leadinglights
That's actually a good question and not easy to answer. For example, the Alligator Board design was made in Altium. Accordingly, a maker having the actual source files would need to buy a licence for that application just to read these sources. Not exactly the ideal situation.
This is another point where software and hardware differ quite a bit. With hardware, expensive applications with proprietary data formats are far more common than in the software world.
Re: Open source licence, but no sources. February 05, 2015 04:13PM |
Traumflug
rmlrn
GPL doesn't apply in this case.
