Heated bed won't heat February 08, 2015 12:40AM |
Re: Heated bed won't heat February 08, 2015 07:47AM |
Re: Heated bed won't heat February 09, 2015 01:15AM |
the_digital_dentist
It sounds like there's a short circuit around the MOSFET switch and when the switch turns on the the short is pulling the power supply voltage down. Monitor the power supply voltage to the RAMPS board and see what it does when the switch turns on and off.
the_digital_dentist
Look for solder blobs on the RAMPS board, check the wires to make sure they aren't frayed and shorting or touching anything they shouldn't.
the_digital_dentist
When you ay the display dims do you mean the backlight dims or does the display contrast wash out or both? Does it do this with and without a USB port connection to your computer?
the_digital_dentist
I had a problem where the 5V regulator on the Arduino board was bad and the display looked fine while I was plugged into the USB port on a computer (because the USB port supplied the 5V to the display), but when I disconnected from the computer I couldn't read the display.
Re: Heated bed won't heat February 09, 2015 01:36AM |
Re: Heated bed won't heat February 09, 2015 09:16AM |
Re: Heated bed won't heat April 28, 2015 01:58PM |
