belt pitch causes ribs on surface February 22, 2015 10:12AM |
Re: belt pitch causes ribs on surface February 22, 2015 11:01AM |
Re: belt pitch causes ribs on surface February 22, 2015 12:03PM |
Re: belt pitch causes ribs on surface February 22, 2015 02:41PM |
I travel 80mm/s (G0) and print at maximum 60mm/s (30mm/s for outer perimeter) and and acceleration of 200mm/s2Quote
ggherbaz
You mentioned 200 mm/sec .
But every rib is exactly above the other: and I printed over 100 layers high (0,15mm * 100 layers)Quote
Dirty Steve
that's not from belt teeth, it's from overpowered drivers and acceleration settings.
Re: belt pitch causes ribs on surface February 22, 2015 04:06PM |
Re: belt pitch causes ribs on surface February 22, 2015 04:21PM |
Dirty Steve
It is not the belt teeth, but the degrees of the stepper motors.
If you move an axis by hand while the motors are powered, that point it clicks to is 1.8 degrees of the motor.
Re: belt pitch causes ribs on surface February 22, 2015 04:27PM |
Re: belt pitch causes ribs on surface February 22, 2015 04:37PM |
Re: belt pitch causes ribs on surface February 22, 2015 04:41PM |
Re: belt pitch causes ribs on surface March 11, 2015 08:10AM |
Re: belt pitch causes ribs on surface March 11, 2015 11:43AM |
Bill Clark
Was this problem ever solved? ... I did notice an effect on this issue during a recent print, I typically print slow (20-40mm/sec) but decided to crank up the speed to 400% and although things started to get a little sloppy, somewhere between 100 and 400%, the ribbing went away. Why did this happen?
Re: belt pitch causes ribs on surface March 11, 2015 07:23PM |
