What is this board ? February 25, 2015 05:51AM |
Re: What is this board ? February 25, 2015 09:14AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: What is this board ? February 25, 2015 09:21AM |
Re: What is this board ? February 25, 2015 10:32AM |
Re: What is this board ? February 25, 2015 11:21AM |
Re: What is this board ? February 25, 2015 11:35AM |
tchitchou
It comes with a chinese rostock mini pro, and I have trouble to find the good wirings for the fans, heat bed, extruder etc..
Re: What is this board ? February 25, 2015 11:46AM |
Re: What is this board ? February 25, 2015 11:52AM |
Re: What is this board ? February 25, 2015 11:54AM |
Re: What is this board ? February 25, 2015 01:18PM |
Re: What is this board ? February 25, 2015 02:02PM |
Re: What is this board ? February 25, 2015 02:30PM |
Re: What is this board ? February 25, 2015 04:31PM |
tchitchou
I know, we have a burlesque discussion for a month now, me telling it's not a ramps 1.4, and it's not working, and him telling it is.
And no more response from him since 10 days.
So, here I am.
Re: What is this board ? February 25, 2015 04:32PM |
Re: What is this board ? February 25, 2015 08:00PM |
tchitchou
Yes, I have a website, and a link, I donwloaded a package, firmware, driver, softwares, assembly instructions, etc.
Assembling was ok, but the board isn't the same as the PDF..
Driver worked..
Upload firmware, ok..
But
I wired the fan on "fan1" connection, but when I switch on the fan in Repetier, it's the heat bed that heats...
I suspect same problems with the endstops..
And the seller no long responds
So, here I am.
Re: What is this board ? February 26, 2015 04:08AM |
Re: What is this board ? February 26, 2015 04:17AM |
Re: What is this board ? February 26, 2015 05:32AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: What is this board ? February 26, 2015 05:54AM |
Re: What is this board ? February 26, 2015 06:30AM |
Re: What is this board ? February 27, 2015 03:25PM |
Re: What is this board ? February 28, 2015 01:36AM |
iamdarkyoshi
I just wanted to see if there are any regulatory markings on the pcb (such as a date code, revision number, ect)
Re: What is this board ? February 28, 2015 05:01AM |
Re: What is this board ? February 28, 2015 02:03PM |
Re: What is this board ? February 28, 2015 05:14PM |
//// The following define selects which electronics board you have. Please choose the one that matches your setup // 10 = Gen7 custom (Alfons3 Version) "https://github.com/Alfons3/Generation_7_Electronics" // 11 = Gen7 v1.1, v1.2 = 11 // 12 = Gen7 v1.3 // 13 = Gen7 v1.4 // 2 = Cheaptronic v1.0 // 20 = Sethi 3D_1 // 3 = MEGA/RAMPS up to 1.2 = 3 // 33 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed) // 34 = RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed) // 35 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan) // 4 = Duemilanove w/ ATMega328P pin assignment // 5 = Gen6 // 51 = Gen6 deluxe // 6 = Sanguinololu < 1.2 // 62 = Sanguinololu 1.2 and above // 63 = Melzi // 64 = STB V1.1 // 65 = Azteeg X1 // 66 = Melzi with ATmega1284 (MaKr3d version) // 67 = Azteeg X3 // 68 = Azteeg X3 Pro // 7 = Ultimaker // 71 = Ultimaker (Older electronics. Pre 1.5.4. This is rare) // 72 = Ultimainboard 2.x (Uses TEMP_SENSOR 20) // 77 = 3Drag Controller // 8 = Teensylu // 80 = Rumba // 81 = Printrboard (AT90USB1286) // 82 = Brainwave (AT90USB646) // 83 = SAV Mk-I (AT90USB1286) // 84 = Teensy++2.0 (AT90USB1286) // CLI compile: DEFINES=AT90USBxx_TEENSYPP_ASSIGNMENTS HARDWARE_MOTHERBOARD=84 make // 9 = Gen3+ // 70 = Megatronics // 701= Megatronics v2.0 // 702= Minitronics v1.0 // 90 = Alpha OMCA board // 91 = Final OMCA board // 301= Rambo // 21 = Elefu Ra Board (v3) // 88 = 5DPrint D8 Driver Board // 999 = Leapfrog #ifndef MOTHERBOARD #define MOTHERBOARD 6 #endif
Re: What is this board ? March 01, 2015 01:36AM |
Re: What is this board ? March 01, 2015 03:59AM |
Re: What is this board ? March 01, 2015 04:04AM |
Re: What is this board ? March 01, 2015 04:12AM |
Re: What is this board ? March 01, 2015 04:38AM |
Ohmarinus
I downloaded the package that the seller sent you. I said this before, there is a map Sanguino in there, probably or a good reason. I'm not sure if I'm just being ignored but it's all there and I'm pretty convinced that your board will work as a sanguino.
