Parts in Autodesk Inventor June 08, 2010 06:20AM |
Re: Parts in Autodesk Inventor June 08, 2010 06:24AM |
Re: Parts in Autodesk Inventor June 08, 2010 04:26PM |
Admin Registered: 16 years ago Posts: 476 |
Re: Parts in Autodesk Inventor June 08, 2010 06:08PM |
Re: Parts in Autodesk Inventor June 08, 2010 07:25PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Parts in Autodesk Inventor June 08, 2010 07:44PM |
Re: Parts in Autodesk Inventor June 08, 2010 09:23PM |
Re: Parts in Autodesk Inventor June 08, 2010 10:56PM |
Traumflug
Are these folks around somewhere here or in the Wiki?
Traumflug
I had a look for a free CAD system myself and decided pretty quickly against OpenSCAD, because it's script based and - more importantly - does faceted objects only, the latter like Blender. A better choice would be BRL-CAD or FreeCAD, IMHO, as these can use "true" rounded shapes (NURBS-based or parametric surfaces).
Re: Parts in Autodesk Inventor June 09, 2010 04:11AM |
Re: Parts in Autodesk Inventor June 09, 2010 04:25AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Parts in Autodesk Inventor June 09, 2010 04:32AM |
OpenSCAD homepage
OpenSCAD provides two main modelling techniques: First there is constructive solid geometry (aka CSG) and second there is extrusion of 2D outlines. As data exchange format format for this 2D outlines Autocad DXF files are used. In addition to 2D paths for extrusion it is also possible to read design parametes from DXF files. Besides DXF files OpenSCAD can read and create 3D models in the STL and OFF file formats.
Re: Parts in Autodesk Inventor June 09, 2010 05:52AM |
Re: Parts in Autodesk Inventor June 09, 2010 06:12AM |
Re: Parts in Autodesk Inventor June 09, 2010 07:51AM |
Re: Parts in Autodesk Inventor June 09, 2010 10:11AM |
Re: Parts in Autodesk Inventor June 09, 2010 10:50AM |
Re: Parts in Autodesk Inventor June 09, 2010 01:27PM |
Re: Parts in Autodesk Inventor June 09, 2010 03:42PM |
Re: Parts in Autodesk Inventor June 09, 2010 04:55PM |
Re: Parts in Autodesk Inventor June 09, 2010 06:29PM |
Re: Parts in Autodesk Inventor June 09, 2010 07:18PM |
