Making a PCB?
Posted by kd6hq
Making a PCB?
March 06, 2015 08:47AM
I am considering making my own accessory PCB for the RAMPS 1.4 board. Normally I would just breadboard something like this but this time I'm considering carrying more current than I normally do. Since I've never done this before I was wondering how wide the traces should to carry 12V DC at 5A, 11A and 15A. Various components on the board will include: relays, voltage divider, fuses, fans and lights. This is just an idea of what I want on it, as there may be more components. Anyway does some one have suggested trace widths?
thank you
VDX
Re: Making a PCB?
March 06, 2015 09:27AM
... for higher currents (up to 40A pulsing) I'm designing with 1.2mm tracewidth and additionally solder a piece of copper-wire along the trace ...
Viktor
Re: Making a PCB?
March 07, 2015 07:53AM
kd6hq
Rule of thumb is 0.5 to 1.0 mm track width per Ampére current. There are also calculators to get more precise numbers: [www.4pcb.com] [www.desmith.net] [www.pcbco.com.au]
Re: Making a PCB?
March 08, 2015 05:49PM
When I have high current and not sure that traces are thick enough I put solder everywhere on the track.
VDX
Re: Making a PCB?
March 08, 2015 06:25PM
... only soldering isn't sufficient for really high currents - better solder some copper wire onto the trace, touching/connecting the pins ... copper is much,much more conducting than solder winking smiley
Viktor
Re: Making a PCB?
March 08, 2015 08:21PM
Thanks
I've decided to use the following (from one of the calculators)
3A = .684mm
5A = 1.38mm
11A = 4.10mm
15A = 6.29mm
I went the next step up for each.
thanks again
kd6hq
Re: Making a PCB?
March 09, 2015 11:42AM
If you have ever had a PCB made, what company made it for you?
thanks
Re: Making a PCB?
March 12, 2015 03:58PM
Make sure that you take into account the thickness of the copper when you are calculating this. If the calculations are based on 2oz copper and you get a board with 1oz copper on it, all the calculations go out the window! Ask me how I know this....... eye rolling smiley
Edited 1 time(s). Last edit at 03/12/2015 03:58PM by andy.wpg.
"I have noticed that even those who assert that everything is predestined and that
we can change nothing about it still look both ways before they cross the street"
-Stephen Hawking
Re: Making a PCB?
March 12, 2015 06:26PM
Thanks for the tip. This is my first attempt so your commits are appreciated.
