Mendel90 vs Prusa i3 - which one to build March 09, 2015 03:45PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 04:27PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 04:36PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 04:53PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 05:15PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 05:37PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 06:00PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 06:38PM |
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 09:13PM |
vorac
I checked the P3Steel. It's built on the same idea of the Mendel90, I guess. But you don't need all those plastic parts to assemble the sheets. Do you know what's the print quality? It's an improvement compared to the Prusa i3 or to the Mendel90?
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 09:20PM |
Zavashier
I'm a Prusa i3 user. To me the Mendel90 is better for many reasons, the cheap and simple wood frame, less steel for the rods, wire management, and so on.
I didn't know the P3Steel. Interesting but why don't they rework the I3 for folded sheet metal technology ? Since you use steel sheets, it's cheaper, easyer and stiffer than using screws like on unfoldable materials. Unfortunately they stopped at half the way.
Re: Mendel90 vs Prusa i3 - which one to build March 09, 2015 10:14PM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 04:17AM |
Opinion depends of the way you look at a piece. You can consider it stands at the top of the tops as it is, or you can appreciate it could be even better. My feeling about the P3Steel is the guy just attempt to swap i3's design out of steel instead of any traditional materials. I guess the inital thought was to reduce cost and get stiffness. But when you want to use a material, you want to use a technology that takes advantage of that material. As engineer I would say, there's no reason to get more vibrations with folded metal sheet. Hardware won't dump vibrations that much, it will work as a transmitter anyways. There's no reason it gets more expensive too. Quite the contrary, you'll need less hardware which have a cost, and the laser will be quicker if it does not cut all that pockets and holes. When you cut spare parts, you need to waste some material between the parts. With the folding technology, you reduce the number of the parts, so you reduce waste. At the same time your product will be more stiff, more precise, and easy to build. Just fold the sheet at the right angle and you're done. I hope this will help you to appreciate what sheet metal is all aboutQuote
AndrewBCN
Zavashier,
There would be nothing to be gained by going to folded steel sheet from laser cut 3mm steel, actually you would make the frame more expensive and more prone to vibrations. You would be surprised by how smooth running and almost silent the P3Steel is, specially when using 1/32 microstepping with DRV8825 drivers. Well, I know I was.
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 05:34AM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 06:56AM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 07:23AM |
Zavashier
Don't get me wrong, I don't say the P3Steel can't be any good. Just seems to me that half the way is done ...
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 07:38AM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 08:58AM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 09:12AM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 10:06AM |
What he said. You're buying from THE source and zero chance you're getting some random piece of crap from someone looking to make a quick buck with inferior printed parts.
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 05:05PM |
Re: Mendel90 vs Prusa i3 - which one to build March 10, 2015 06:01PM |
Re: Mendel90 vs Prusa i3 - which one to build March 11, 2015 01:07PM |
I think you would spend less getting a fasteners set from the link I posted above.Quote
vorac
I decided I want to source everything I can. Do you know a good online store to buy fasteners? I dont want one where I have to buy at least 25 or 100 pieces, I already found those. I know stores where you can buy even 1 bolt exist but can't find them!
Re: Mendel90 vs Prusa i3 - which one to build March 11, 2015 02:45PM |
I purchased almost all my bolts/screws from boltdepot.com.Quote
vorac
Re: Mendel90 vs Prusa i3 - which one to build March 12, 2015 03:32PM |
Re: Mendel90 vs Prusa i3 - which one to build March 12, 2015 04:56PM |
The extruder could have been printed out to be used with one of several different styles of hot ends. The "J-Head" mount is probably the most likely.Quote
vorac
The plastic parts set I've bought has a Wade's Greg extruder. Will any hotend fit in it?
What do you plan on printing? If you are going with just PLA, J-Head. If want ABS, either. If you want PLA or ABS, but also don't want to exclude other higher temp plastics like nylon or polycarbonate, then E3D. Some people say they have more difficulties with PLA and a E3D.Quote
Basically I saw that the two most used hotends are E3D and J-Head. Which one would you recommend?
Re: Mendel90 vs Prusa i3 - which one to build March 13, 2015 04:43AM |
