Glass sheet March 18, 2015 06:15AM |
Re: Glass sheet March 18, 2015 07:32AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Glass sheet March 18, 2015 07:39AM |
Re: Glass sheet March 18, 2015 08:20AM |
Re: Glass sheet March 18, 2015 09:53AM |
Re: Glass sheet March 18, 2015 12:12PM |
Re: Glass sheet March 20, 2015 05:16AM |
Re: Glass sheet March 20, 2015 05:37AM |
Re: Glass sheet March 20, 2015 06:46AM |
Re: Glass sheet March 20, 2015 06:50AM |
Re: Glass sheet March 20, 2015 06:57AM |
Re: Glass sheet March 20, 2015 07:06AM |
Re: Glass sheet March 20, 2015 11:04AM |
skynetprinter
no plastic sticks to glass, only kapton tape does. for PLA i use paper adhesive which is awesome, the PLA sticks straight to the aluminium fairly well too. you don't need to use only one print bed too... it's a myth. you can have .2 mm gaps in the print substrate the print will be fine. you can use des bosses under the substrate and holes in the alu to keep all in place if you wished, the print would be the same, the main issue is perfect flatness of substrate and stickyness using paper or abs acetone mix.
Re: Glass sheet March 20, 2015 03:04PM |
tjb1
I print PLA right on glass...care to explain that?
Re: Glass sheet March 23, 2015 01:32AM |
Re: Glass sheet March 23, 2015 01:56AM |
Re: Glass sheet March 23, 2015 04:09AM |
Re: Glass sheet March 23, 2015 06:14AM |
Re: Glass sheet March 23, 2015 06:58AM |
Re: Glass sheet March 23, 2015 07:33AM |
Re: Glass sheet March 23, 2015 09:25AM |
Re: Glass sheet March 23, 2015 10:27AM |
3DPrintingNoob
1. Why would I need the aluminium base to attach the silicone heaters? Wouldn't it just be enough to attach them to the glass? The glass would just conduct the heat from the beds wouldn't it?
3DPrintingNoob
2. I will be using the same heaters throughout (equal in power and resistance, etc.)
3DPrintingNoob
3. Would the beds need to have a low temperature coefficient of resistance?
3DPrintingNoob
4. I have to conduct an FMEA for the heatbeds configuration (i.e. in parallel and series). The fact that the thermistor won't record the average temperature but rather hottest temperature may not be enough. Would you suggest an alternative or is this the most efficient way? If this is the simplest and most efficient way then it's accepted.
3DPrintingNoob
5. The bed will only be moving in the Z direction so there shouldn't be a problem.
3DPrintingNoob
6. Is ABS slurry basically a mixture of ABS filament and acetone? How would I mix the ABS? Would I need to chop the filament into little pieces?
Re: Glass sheet March 23, 2015 01:47PM |
dc42
Glass is a poor conductor of heat. A glass bed is thin enough to conduct heat reasonably well from one face to the other, but it won't conduct well in the plane of the bed. The silicone heaters won't produce heat uniformly over their surfaces, and they won't produce heat right at the edges, especially if you have small gaps between the heaters. So I strongly recommend a heat spreader. Maybe borosilicate glass would stand up to the uneven heating, maybe not. Also, if you were to break or damage the glass for whatever reason, you would be faced with somehow removing the silicone heaters and attaching them to a new piece of glass.
dc42
They may be nominally of equal power, but do you know what the manufacturing tolerance on the resistance is?
dc42
Not necessarily, if you connect them in parallel. With parallel connection, the hottest beds will take less power as they heat up. With series connection, the hottest beds will draw more power as they heat up, which is not a good thing even though thermal runaway is unlikely. But the heaters may have a low temperature coefficient of resistance anyway, depending on what the conductors are made from. Ask the supplier.
dc42
From an FMEA perspective, series connection of the heating elements has the advantage that if one bed heater goes open circuit, the whole bed shuts down. So you will definitely realise that something is wrong. Whereas with parallel connection, ideally you would monitor the thermistors individually so that you can detect when a heater has failed. An alternative would be to monitor the total current drawn by the heaters.
dc42
That helps, but you still need to provide strain relief at both ends of the cable, and ensure that the cables can't chafe on anything. And I suggest you choose highly flexible cable.
dc42
Yes. You need only cut the filament into small enough pieces to fit in the bottle that you are mixing the slurry in. Or you can buy solvent pipe cement, which is much the same thing as ABS slurry.
Re: Glass sheet March 23, 2015 02:02PM |
Re: Glass sheet March 23, 2015 03:31PM |
Re: Glass sheet March 23, 2015 03:34PM |
skynetprinter
Why would you use silicone heat beds on aluminium instead of resistors? resistors have pretty precise resistance, and you can also use a number of reprap heatbeds, which can go from 24 volts.
PET and FR4 both seem like good printing substrage, because you can remove them and bend them to get the plastic off. makerbot uses pet sheet instead of glass.
Re: Glass sheet March 24, 2015 07:45AM |
Re: Glass sheet March 24, 2015 09:02AM |
3DPrintingNoob
The only problem will be the flatness of the plate because if it's really large (as it already will be) then by supporting only the 4 corners, it would tend to create a well in the middle of the plate, if it's heavy enough. Even more so when heated.
Re: Glass sheet March 24, 2015 10:08AM |
Re: Glass sheet March 24, 2015 10:39AM |
