Re: Glass sheet
March 24, 2015 11:18AM
If you will be using glass on top of the bed to print on, then you could get away with setting a few small (e.g. M3) countersunk screws into the top surface. Alternatively, as the ribs are for supporting the aluminium, perhaps you can get away with attaching the ribs at the edges of the plate only.
It's also possible to bond aluminium with epoxy resin, if you prepare the surface first.
Re: Glass sheet
March 30, 2015 07:16AM
Good news, the aluminium plate will only be 800 x 800mm now. Also, the ribs will be machined out from the bottom of the plate. It's not too expensive, not too heavy, and definitely more rigid. It might be decided to just print onto the aluminium plate but perhaps with PET sheets on top or a metallic skin.
Thank you
The (getting better) Noob
Zapadee zoopidee.
