Laser cutter without a laser March 24, 2015 10:25AM |
Re: Laser cutter without a laser March 24, 2015 04:22PM |
Re: Laser cutter without a laser March 24, 2015 04:56PM |
Re: Laser cutter without a laser March 24, 2015 06:10PM |
Re: Laser cutter without a laser March 24, 2015 11:11PM |
Re: Laser cutter without a laser March 25, 2015 01:25AM |
Zavashier
I can't reach your link, country restrictions...
Re: Laser cutter without a laser March 25, 2015 06:55AM |
Re: Laser cutter without a laser March 25, 2015 07:18AM |
Here is why this will fail. Whith hot wire technology, even foam has its limits. The good point about styrofoam, is that retracts far from the hotwire, so it stays dry. Seccond, styrofoam can retract until a few percentage of the initial volume. Because that material density is very low. If the material density grows, the retractation decreases, and so the ability to cut it. If you try to melt foam, you will notice than up to 20-25% of rectactaction, it forms a hard skin which is more difficult to be melted. So if you need to cut a "T", the seccond path will be much harder to cut than the first one. And you will never be able to remove a pocket. But, much more important : What will you do with the material fused by your path ? If you don't remove it, it will flow or clogg. That's the most important reason why it will fail.Quote
skynetprinter
but it's totally possible... how could it fail?
Re: Laser cutter without a laser March 25, 2015 11:02AM |
some materials would cut better than others because the material just retratracts
i know it isnt a very genius invention.|
Re: Laser cutter without a laser March 25, 2015 12:52PM |
