Why does ABS stick differently to different types of glass? March 29, 2015 06:07AM |
Re: Why does ABS stick differently to different types of glass? March 29, 2015 02:11PM |
Re: Why does ABS stick differently to different types of glass? March 30, 2015 02:04PM |
Re: Why does ABS stick differently to different types of glass? March 31, 2015 02:49PM |
Re: Why does ABS stick differently to different types of glass? March 31, 2015 03:17PM |
Re: Why does ABS stick differently to different types of glass? April 01, 2015 07:58AM |
Re: Why does ABS stick differently to different types of glass? April 01, 2015 10:00AM |
Re: Why does ABS stick differently to different types of glass? April 01, 2015 10:09AM |
Re: Why does ABS stick differently to different types of glass? April 01, 2015 02:30PM |
lunarkingdom
Why do anything other than what works when you have been given a recipe for success?
Re: Why does ABS stick differently to different types of glass? April 05, 2015 06:04AM |
Re: Why does ABS stick differently to different types of glass? April 05, 2015 12:19PM |
Re: Why does ABS stick differently to different types of glass? April 05, 2015 02:10PM |
Re: Why does ABS stick differently to different types of glass? April 12, 2015 12:21PM |
Re: Why does ABS stick differently to different types of glass? April 12, 2015 12:24PM |
Re: Why does ABS stick differently to different types of glass? April 12, 2015 01:59PM |
Rich K.
I have had bad luck with regular glass - it always cracks in half when I get up to 120 degrees. I haven't had a problem with borosilicate glass.
Re: Why does ABS stick differently to different types of glass? April 13, 2015 08:55PM |
leadinglights
I do know that old greenhouse glass (3mm) worked splendidly for a while without even ABS juice but got poorer and poorer adhesion no matter how it was cleaned until it had been left on a shed roof for most of the summer. After long exposure to the sun (UV??) and rain it was good again. Things which had failed to clean and re-establish adhesion included acetone, Fairy washing up liquid, very fine wire wool and many combinations along with boiling water to rinse off.
Mike
Re: Why does ABS stick differently to different types of glass? April 14, 2015 05:52AM |
Re: Why does ABS stick differently to different types of glass? April 15, 2015 09:30PM |
And they all lived happily ever after, the end! Simples.
Re: Why does ABS stick differently to different types of glass? April 16, 2015 04:27AM |
Re: Why does ABS stick differently to different types of glass? April 16, 2015 07:17AM |
Re: Why does ABS stick differently to different types of glass? April 16, 2015 12:47PM |
Re: Why does ABS stick differently to different types of glass? April 16, 2015 06:55PM |
Re: Why does ABS stick differently to different types of glass? April 17, 2015 06:46AM |
perhaps? except that the guy doesnt demonstrate the end result, perhaps it was only 3 layers high. Hunting down glass is pretty good, there is often alot lying about in waste sites and it's every time a different chemistry, i am learning to cut with the hot straight element of the oven or a string wicked in a flammable solvent in order to heat and cut stright lines.
