PSU and Extruder problems April 03, 2015 06:47AM |
Re: PSU and Extruder problems April 03, 2015 08:35AM |
Re: PSU and Extruder problems April 03, 2015 08:37AM |
Re: PSU and Extruder problems April 03, 2015 10:14AM |
gordonendersby
Is the psu thats not giving 12v a pc power supply as well?
As they use the 5v line to regulate power. Unless you put a load on the 5v supply it will not supply a good 12v.
[reprap.org]
Gordon
AndrewBCN
The motors stuttering probably has nothing to do with the PSU but is caused by not having adjusted the Vref on the stepper drivers.
The voltage drop when the heatbed is turned on is due to poor regulation with an unbalanced load.
The solutions for both problems can be found in the wiki, a quick search will get you to the correct pages.
Re: PSU and Extruder problems April 03, 2015 10:26AM |
wes1007
I had the 650W PSU set up with the one 18A rail running just the Heated bed on my Ramps board and the other Rail ran the hot-end+drivers. Thought that running them on separate Rails would be the same as running them on separate PSUs (which is working fine right now)
Re: PSU and Extruder problems April 03, 2015 10:32AM |
dc42
wes1007
It's not quite the same thing, because most ATX PSUs have only one feedback loop, so the two 12V and the single 5V output are not independent of each other. Still, I would have expected that arrangement to work, provided you had sufficient minimum load on each rail.
I ran a single-head 3D printer quite successfully from a single 550W ATX PSU for a while and later from a 430W PSU. I was using the ATX12V connector to power everything, and both PSUs had a single 12V output current rating. I'm wondering how the ATX12V is wired in a PSU with multiple 12V outputs. Maybe it's independent of the other 12V outputs and also needs a minimum load?
Re: PSU and Extruder problems April 03, 2015 10:51AM |
wes1007
My understanding of the rails is that they are completely independent. If you have a high end GPU and it strats to draw a lot of amps this wont affect your harddrives ruynning on a different rail.
Sadly I have no idea why I'm having problems with it. It is an old PSU and maybe its seen better days. Will look at fetching a new one from work and hooking it up to test.
Re: PSU and Extruder problems April 03, 2015 12:10PM |
Nope.Quote
Re: PSU and Extruder problems April 03, 2015 05:51PM |
Re: PSU and Extruder problems April 03, 2015 06:04PM |
Re: PSU and Extruder problems April 03, 2015 06:15PM |
AndrewBCN
Nope.Quote
Two things again:
1) Power supplies with two rails almost always mean they have separate overcurrent protection on each rail, but both rails actually derive their voltage from the same secondary circuit.
2) Old power supplies sometimes have bad regulation of the +12V rail even if you provide a significant load on the +5V and +3.3V rails. This is why (among other things) I strongly recommend in the wiki to avoid using old ATX PSUs. Buy a new, good quality one and avoid many headaches and possible accidents. Recommendations are in the wiki.
Finally, "Vref is okay on the drivers." is not good enough information. Exactly what drivers do you have, what is the Rs on them and what is the voltage you have set them to?
jaguarking11
I see no reason to not use a server psu. While cheap used. They are one trick pony with usually 50+ amps 12v rails.
dc42
I am very happy with Chinese LED power supplies. Like ATX PSUs, they are short-circuit protected; but unlike ATX PSUs, the voltage is adjustable - which is handy if you have a heated bed that struggles to get hot enough for ABS printing - and they don't require minimum loads. The downsides are that they are probably not as reliable as top-brand ATX PSUs (OTOH you can buy 2 of them for the price of one branded ATX PSU), you need to do mains wiring and make an enclosure to protect it, they don't give you a 5V output (which modern printer electronics boards don't need anyway), and they don't have a standby function.
Re: PSU and Extruder problems April 03, 2015 07:31PM |
wes1007
dc42
Ive debated getting some of these...however i do plan to run my heated bed off 24V sometime so having the adjustable voltage isn't really necessary for me. could always have a "standby" mode by running the LED power supply through a relay.
Re: PSU and Extruder problems April 04, 2015 03:28AM |
dc42
wes1007
dc42
You can get 24V LED PSUs too. Using modern printer electronics, you can run the entire printer from 24V and benefit from increased maximum stepper motor speed. Probably the trickiest part to source cheaply is a 24V hot end fan, but you can use always revert to using a 7812 regulator to drive a 12V fan.
Re: PSU and Extruder problems April 05, 2015 06:33PM |
Re: PSU and Extruder problems April 05, 2015 07:37PM |
Re: PSU and Extruder problems April 05, 2015 07:57PM |
AndrewBCN
Check the resistance between the D8 terminals with the RAMPS disconnected from everything. If it's zero you have found your short circuit.
Re: PSU and Extruder problems April 05, 2015 08:52PM |
Re: PSU and Extruder problems April 06, 2015 02:10AM |
Re: PSU and Extruder problems April 06, 2015 06:50AM |
Re: PSU and Extruder problems April 06, 2015 07:11AM |
Re: PSU and Extruder problems April 06, 2015 07:58AM |
Re: PSU and Extruder problems April 06, 2015 08:08AM |
Re: PSU and Extruder problems April 06, 2015 10:17AM |
RAMPS 1.4 doesn't have different size traces for D8-D10.They're all the same. (unless someone redesigned the circuit board). The 11A fuse though still holds true why you can't switch to a different output.Quote
AndrewBCN
The heated bed from the D10 connector: DON'T!!! The large current traces and the 11A fuse on the RAMPS are only for the D8 connector.
Re: PSU and Extruder problems April 06, 2015 10:35AM |
Re: PSU and Extruder problems April 06, 2015 11:26AM |
cdru
RAMPS 1.4 doesn't have different size traces for D8-D10.They're all the same. ....Quote
AndrewBCN
Re: PSU and Extruder problems April 06, 2015 04:09PM |
AndrewBCN
cdru
AndrewBCN
As far as I can see the islands (marked as dotted lines) for the 11A circuit path provide a lot more copper than the traces for the 5A circuit path. And they are shorter, too.
Re: PSU and Extruder problems April 08, 2015 04:07PM |
