Functional Workflow of a reprap? June 18, 2010 02:11PM |
Re: Functional Workflow of a reprap? June 18, 2010 02:55PM |
What gets transferred from the PC to the reprap?? Is that g-codes?
Does that mean that g-code files can be shared?
Is the CAD-like front end responsible for generating the g-codes, or whatever data gets transfered to the reprap?
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Functional Workflow of a reprap? June 18, 2010 02:57PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Functional Workflow of a reprap? June 18, 2010 08:14PM |
Re: Functional Workflow of a reprap? June 19, 2010 01:51AM |
So if gcode is sent to the reprap, it should be easy to use an alternate controller for the reprap?
Also, whatever controller is used should also be able to control other build platforms, such as a cnc router, or larger rapid prototyper, right?
Does that mean that the electronics are identical between the reprap and the makerbot?
Re: Functional Workflow of a reprap? June 22, 2010 11:38AM |
Re: Functional Workflow of a reprap? June 22, 2010 11:54AM |
CrawlerLogger
If I built one of these, could I build the other using the same motors and electronics.
Re: Functional Workflow of a reprap? June 28, 2010 03:36PM |
Re: Functional Workflow of a reprap? June 28, 2010 04:27PM |
Is there plans to incorporate rotary encoders on the steppers at some point in the development?
Or can motors with the shaft on only one side work?
Re: Functional Workflow of a reprap? June 28, 2010 04:30PM |
Re: Functional Workflow of a reprap? June 28, 2010 05:27PM |
