Alternative ABS Coil resource?
Posted by eooojj
June 21, 2010 06:38AM
I am located at Singapore. To ship a coil of ABS here will double the price of the ABS coil. I wonder if anyone has links to places that sells these coils cheaper or any extrusion method i can use to convert readily available ABS pellets into similar coils.
Re: Alternative ABS Coil resource?
June 21, 2010 02:21PM
You might want to look for a local supplier of ABS plastic welding rods, which is often readily available from several places.
There might be some quality issues which can make a problem for extrusion though, so try out a bit first.
