Steppers not stepping correctly - Mega and Pololu June 22, 2010 01:25PM |
Re: Steppers not stepping correctly - Mega and Pololu June 22, 2010 02:51PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Steppers not stepping correctly - Mega and Pololu June 22, 2010 04:58PM |
Re: Steppers not stepping correctly - Mega and Pololu June 22, 2010 06:28PM |
/* PololuTestMega Runs 3 Pololu stepper boards by controlling the Direction, Enable and Step pins Arduino Mega RepStrap Electronics Created 16 June 2010 By Al Adrian */ const int Enablex = 24; // Enable pin x as per Hydra Firmware const int Directionx = 28; // Direction pin x const int Stepx = 26; // Step pin x const int Enabley = 30; // Enable pin y const int Directiony = 34; // Direction pin y const int Stepy = 32; // Step pin y const int Enablez = 36; // Enable pin z const int Directionz = 40; // Direction pin z const int Stepz = 38; // Step pin z int Delay; int Cnt; int Circle; // The setup() method runs once, when the sketch starts void setup() { // initialize the digital pins as output: pinMode(Enablex, OUTPUT); pinMode(Directionx, OUTPUT); pinMode(Stepx, OUTPUT); pinMode(Enabley, OUTPUT); pinMode(Directiony, OUTPUT); pinMode(Stepy, OUTPUT); pinMode(Enablez, OUTPUT); pinMode(Directionz, OUTPUT); pinMode(Stepz, OUTPUT); digitalWrite (Directionx, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Directiony, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Directionz, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Enablex, LOW); //LOW is Pololu enabled digitalWrite (Enabley, LOW); //LOW is Pololu enabled digitalWrite (Enablez, LOW); //LOW is Pololu enabled Delay = 1000; //microseconds Circle = 9999; //400 steps around on the little motor, *16 for the 1/16 mode minus1 } // the loop() method runs over and over again, // as long as the Arduino has power void loop() { digitalWrite(Stepx, HIGH); // set the Step on digitalWrite(Stepy, HIGH); // set the Step on digitalWrite(Stepz, HIGH); // set the Step on delayMicroseconds(Delay); // wait for a tenth second digitalWrite(Stepx, LOW); // set the Step off digitalWrite(Stepy, LOW); // set the Step off digitalWrite(Stepz, LOW); // set the Step on delayMicroseconds(Delay); // wait for a tenth second }
Re: Steppers not stepping correctly - Mega and Pololu June 26, 2010 09:48PM |
Re: Steppers not stepping correctly - Mega and Pololu June 27, 2010 06:47PM |
/* PololuTestMega Runs 3 Pololu stepper boards by controlling the Direction, Enable and Step pins Arduino Mega RepStrap Electronics Created 16 June 2010 By Al Adrian */ const int Enablex = 24; // Enable pin x as per Hydra Firmware const int Directionx = 28; // Direction pin x const int Stepx = 26; // Step pin x const int Enabley = 30; // Enable pin y const int Directiony = 34; // Direction pin y const int Stepy = 32; // Step pin y const int Enablez = 36; // Enable pin z const int Directionz = 40; // Direction pin z const int Stepz = 38; // Step pin z int i; int Delay; int Cnt; int Circle; // The setup() method runs once, when the sketch starts void setup() { // initialize the digital pins as output: pinMode(Enablex, OUTPUT); pinMode(Directionx, OUTPUT); pinMode(Stepx, OUTPUT); pinMode(Enabley, OUTPUT); pinMode(Directiony, OUTPUT); pinMode(Stepy, OUTPUT); pinMode(Enablez, OUTPUT); pinMode(Directionz, OUTPUT); pinMode(Stepz, OUTPUT); digitalWrite (Directionx, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Directiony, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Directionz, LOW); //LOW Clockwise, HIGH Counter Clockwise digitalWrite (Enablex, LOW); //LOW is Pololu enabled digitalWrite (Enabley, LOW); //LOW is Pololu enabled digitalWrite (Enablez, LOW); //LOW is Pololu enabled Delay = 60; //microseconds Circle = 9999; //400 steps around on the little motor, *16 for the 1/16 mode minus1 } // the loop() method runs over and over again, // as long as the Arduino has power void loop() { digitalWrite(Directionx, LOW); // set the Direction low digitalWrite(Directiony, LOW); // set the Direction HIGH digitalWrite(Directionz, LOW); // set the Direction HIGH for (int i = 0; i < 100; i++){ digitalWrite(Stepx, HIGH); // set the Step on digitalWrite(Stepy, HIGH); // set the Step on digitalWrite(Stepz, HIGH); // set the Step on delayMicroseconds(Delay); // wait for a tenth second digitalWrite(Stepx, LOW); // set the Step off digitalWrite(Stepy, LOW); // set the Step off digitalWrite(Stepz, LOW); // set the Step on delayMicroseconds(Delay); // wait for a tenth second delay(20); } digitalWrite(Directionx, HIGH); // set the Direction HIGH digitalWrite(Directiony, HIGH); // set the Direction HIGH digitalWrite(Directionz, HIGH); // set the Direction HIGH for (int i = 0; i < 100; i++){ digitalWrite(Stepx, HIGH); // set the Step on digitalWrite(Stepy, HIGH); // set the Step on digitalWrite(Stepz, HIGH); // set the Step on delayMicroseconds(Delay); // wait for a tenth second digitalWrite(Stepx, LOW); // set the Step off digitalWrite(Stepy, LOW); // set the Step off digitalWrite(Stepz, LOW); // set the Step on delayMicroseconds(Delay); // wait for a tenth second delay(20); } }
Re: Steppers not stepping correctly - Mega and Pololu December 18, 2011 10:05AM |
