Who sells the best quality ramps 1.4 board? April 23, 2015 12:23PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 12:47PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 01:38PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 01:44PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 03:24PM |
Mutley3D
Ill agree with dc42's comments aswell in the most part, but all electronics are fragile. Id rather blow a Ramps or Arduino to learn that lesson the cheaper way rather than blowing a Smoothie for example, but that said, a Smoothie is more robust. For a P3 Steel ramps will do for now.
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 04:36PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 04:49PM |
Re: Who sells the best quality ramps 1.4 board? April 23, 2015 04:58PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 11:31AM |
dc42
If you want a good board, my advice is not to use Arduino/RAMPS at all, because it has too many disadvantages e.g. slow USB-over-serial connection without flow control, tricky stepper motor current adjustment, no SD card unless you add an LCD, fragile voltage regulator, 12V power limitation, and poor performance (although sufficient for a Cartesian printer). Choose Duet or Smoothieboard instead. If you can't afford those, then there is little to choose between different RAMPS boards because there is very little on the board besides a pile of connectors. OTOH it is worth spending a little more for good quality driver modules constructed on 4 layer boards, to allow more stepper motor current if you need it.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 11:54AM |
tjb1
Motor current adjustment is a simple trim pot and multimeter, hardly tricky.
tjb1
You can run from SD card without an LCD.
Never had a failed voltage regulator and I have 4-5 RAMPS boards.
tjb1
You can buy a "RAMPS" board from RRD that supports up to 35v I believe, I know for sure you can run it at 24v.
tjb1
Really no reason for someone new to not use RAMPS, it was the standard for a very long time and has a ton of documentation and firmware support.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 12:03PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 12:19PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 12:31PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 01:20PM |
dc42
tjb1
You only need to read these forums to see that a great many people have trouble doing it. Some short the driver board out in the process.
tjb1
Sure you can, if you can find an SD card addon separate from an LCD.
Again, read the forums, there are a lot of reports of failed voltage regulators.
tjb1
Yes, but look at their prices! $59 for a board that is basically a pile of connectors and a few not-very-good mosfets. You still need to add the drivers and the Arduino (or Taurino if you want to run it for 24V) - and then you are spending more than a 32-bit boards costs.
tjb1
It's old, out of date and high time it was retired in favour of something better, with a faster processor, native USB port, decent voltage regulator, and software control of stepper motor currents. Keep the plug-in drivers if you like, that and the fact you can pick up Arduino/RAMPS clones for very little are the only things going for it IMO.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 02:06PM |
tjb1
if someone can't manage to turn a screw to set a voltage than maybe building their own printer isn't something they should be doing.
tjb1
Why do you need a faster processor when RAMPS will do just fine for 90% of printers?
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 02:25PM |
dc42
tjb1
That's a rather contemptuous attitude. All sorts of people build repraps, some with a lot of mechanical experience and zero electronics experience. Software control is also much more convenient. I've just reduced an extruder stepper motor current to resolve a problem with the extruder chewing up filament. I'm glad I didn't have to remove the bed to access the controller and mess around with pots and multimeters.
tjb1
The fact that the atmega2560 is more than double the price of a much more capable 32-bit processor (with around 8x the performance, 6x the RAM and a native USB port) tells me that Arduino/RAMPS is an obsolescent design.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 02:39PM |
tjb1
Your whole argument for getting rid of RAMPS is it being old and not powerful enough..
tjb1
...yet we have nothing new pushing firmwares to require Smoothie or other arm boards.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 03:46PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 04:10PM |
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 05:00PM |
Mutley3D
Theres nothing like a good strong debate - I wont bother with quotes of quotes of quotes
Mutley3D
RAMPs/Arduino are NOT out of date. They are a reliable staple of RepRap. There is far more performance headroom in a Ramps/Arduino setup than people give credit for. Its all about setup.
Mutley3D
And the printers themselves are not really advancing.
Mutley3D
Only Deltas suffer a high computational requirement due to floating point innacuracies on the 8-bit platform.
Mutley3D
In fact the degree of microstepping used on cart based machines is also debatable/excessive.
Mutley3D
As for people blowing things up through adjustment - Often the easiest mistakes are the most common, in this case, fried electronics or drivers through rushing and forgetting often one small step, like using a ceramic or plastic screwdirver for adjustment of pots, or unplugging main power before doing this adjustment. And often for novices and learners the only way of learning these mistakes is a hit on the wallet and a few hours down time.
Mutley3D
All my own machines have Ramps/Arduino (or 8 bit derivative) - Uploading firmware is easy as Pi and quick. In normal operation, i never need to reupload.
Re: Who sells the best quality ramps 1.4 board? April 24, 2015 08:11PM |
Re: Who sells the best quality ramps 1.4 board? April 25, 2015 12:41AM |
Re: Who sells the best quality ramps 1.4 board? April 25, 2015 04:57AM |
Re: Who sells the best quality ramps 1.4 board? June 19, 2015 08:24AM |
Re: Who sells the best quality ramps 1.4 board? June 19, 2015 10:35AM |
But aren't we forget something here?
The person is asking....
