Geting started - which Software/Firmware?
Posted by cysign
April 30, 2015 06:13PM
Hey guys, I'd like to assemble all of my printer's components soon. Therefore I need to know which software is suiteable for my purpose.
I have:
-Arduino Mega2560
-HD44780 display, using PCF8574 i2c-chip
-sd-cardreader
-6 endswitches
-a single extruder with hotend
-Ramps v1.4
-A4988 Pololu drivers
-heatbed
I don't know where to start from on the software side.
Which firmware should I use for my selfmade 3d printer?
What software could you advice for cad/cam purpose?
I'm used to Inventor, and 3D Studio Max....but those are student versions which I would like to avoid using my 3D printer...
On the mechanical side I need to assemble all parts, and add some sheet metal and some solid (i.e. for mounting endswitches...)
Edited 1 time(s). Last edit at 04/30/2015 06:16PM by cysign.
Re: Geting started - which Software/Firmware?
April 30, 2015 07:46PM
you are probably going to want to get marlin firmware:
[github.com]
and to modify it and upload it to your board get the arduino software from their site:
[www.arduino.cc]
May 01, 2015 02:41PM
Is there any complete tutorial/documentation how to configure it?
May 01, 2015 03:12PM
You should chose your printer electronics and firmware together, because not all firmwares run on all electronics. For example, 32-bit electronics can run more advanced firmwares than 8-bit boards such as Arduino Mega.
As you have already chosen Arduino Mega/RAMPS for your electronics, your main firmware choices are Marlin, Repetier, and Teacup. You can search the wiki for more information on these firmwares.
