Nema 17 wiring help
Posted by lunarkingdom
Nema 17 wiring help
May 01, 2015 11:55PM
Hey guys I bought some new nema 17's and they only included these images:
Which ones go to 1A, 1B, 2A and 2B?
I hooked them up like this:
Black - 1A
Green - 2A
Red - 2B
Blue - 1B
And my motors vibrate back and forth when I try to use them. Last time I had this problem I just messed around until I got it right, this time I want to understand what is right, can you help me with this please?
Re: Nema 17 wiring help
May 02, 2015 04:26AM
As pictured its two coils
One coil goes on pins 1 and 2 (2b and 2a) and the second coil to pins 3 and 4 (1a 1b)
With 4 wire steppers it doesnt matter wich end of the coil goes to what pin, so long as both coil ends are togeather on the left or the right two pins.
The motor direction is just reversed, wich you can fix in firmware, or just flip the entire plug around 180 degrees.
So in your case swap black and red wil fix it.
Edited 3 time(s). Last edit at 05/02/2015 04:31AM by Dust.
May 02, 2015 05:43AM
And its all in the manual.
[reprap.org]
Gordon
Currently have a tweaked mendel prusa i2
About to build a P3Steel.
[scratchpad.thisandthose.org]
Printer for hire.
[www.3dhubs.com]
Member of South London Makerspace:
[southlondonmakerspace.org]
May 02, 2015 11:21AM
Dust
Ahh for some reason I paired the A's abd B's instead of the 1'2 and 2's, thanks!!
