Analog reading noise
July 02, 2010 03:18AM
I design a new extruder control PCB. It has AD595A thermocouple ic and a tip122 transistor for driving the heather with PWM.
It works but I saw that when the PWM starts there became a lot of noise with my temperature readings. If it does not active my readings are fine.
Is there a way to solve this issue?
Regards,
Nuri Erginer
VDX
Re: Analog reading noise
July 02, 2010 03:25AM
... filtering the noise with caps or RC-networks or have a better look on the GND-arrangements ...
Viktor
July 02, 2010 04:09AM
I use 100nf cap between analog 0 and GND but it did not solve the problem
July 02, 2010 04:11AM
I found that the AD595 is very sensitive to supply rail noise, so if you get the 5V from a switch mode PSU you will need to filter it. Details here: [hydraraptor.blogspot.com]
July 02, 2010 04:36AM
I will try the same solution to night nophead
I will inform you the results
Thanks alot
July 02, 2010 12:17PM
Here is the result I use 1 k resistor and 25uf cap. It is still noisy while the PWM is active. As you see when it is not active there is a smooth reading. PID is also working on arduino
Do I need bigger cap?
Regards,
Nuri Erginer
July 02, 2010 01:29PM
It looks like a ground problem to me. You need to route the ground current from the heater so that it does not generate voltage drops in the ground path between the AD595A and the Arduino ground pin.
VDX
July 02, 2010 03:54PM
... make the Ground-connections shorter and thicker (resolder GND-trays) and use a smaller cap, not bigger ...
Viktor
July 02, 2010 05:23PM
Nophead you are the best!!
I just solder a wire from the heater transistor ground to the main ground Above is the result.
Viktor I will try a smaller cap thanks.
Edited 1 time(s). Last edit at 07/02/2010 06:45PM by nerginer.
