can the platform disalign mid print from motor error?
Posted by skynetprinter
May 12, 2015 08:01AM
When i run my printer for 3 4 hours all seems ok, but when i came home to do anothe print, in two days i had two 1mm slips on the Y axis, first time was within 2 minutes of a new print, and second time after 10 minutes of a new print.
The belt is very tight, the motor cog is very tightly screwd on, the belt moves freely, the y axis slides very well, I have to try adding greece to it, but i did that 25 hours of printing ago.
Can the reprap disalign for other reasons?
Re: can the platform disalign mid print from motor error?
May 12, 2015 10:26AM
yes missing steps id check what volts you supplying to the particular motor in question
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
May 12, 2015 10:29AM
What RepRap design are you using?
NFireLabs - The World First Modular 3D Printer - At An Affordable Price!
May 12, 2015 10:31AM
Check your acceleration and jerk settings. Setting them properly requires adjustments during a complex structure print, not a simple cube or cylinder. If acceleration/jerk are too high the machine will miss steps. The Y axis is particularly vulnerable because of the typically higher moving mass.
May 12, 2015 02:56PM
Thanks alot! i will check it out.
It's a prusa i3.
May 12, 2015 03:18PM
where are the acceleration and jerk settings located, probably in the firmware? Where to look?
May 12, 2015 06:06PM
config.h
May 12, 2015 06:19PM
Thanks!
May 13, 2015 04:10AM
Are you printing onto a glass bed which is on a heated plate?
If so, make sure that the glass is fixed to the bed with sufficient force!
I once tried to tape it down with tape, and I was getting crazy step skips.
It was the bed sliding about which caused it!
This may not be your issue.
Regards
