Extruder melt-back woes! July 07, 2010 10:09AM |
Re: Extruder melt-back woes! July 07, 2010 10:19AM |
Re: Extruder melt-back woes! July 07, 2010 11:05AM |
Re: Extruder melt-back woes! July 07, 2010 11:21AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Extruder melt-back woes! July 07, 2010 11:37AM |
Re: Extruder melt-back woes! July 07, 2010 11:56AM |
Assuming you cannot stop the filament from melting back along it's length, how far back from the barrel does it melt to the point that it can bulge out?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Extruder melt-back woes! July 07, 2010 03:22PM |
Re: Extruder melt-back woes! July 07, 2010 04:18PM |
The conclusion is, the entry end of the barrel has to be colder than the filament's melting temperature.
If you used a longer tip, and drilled it out of stainless steel rod. If you make the threaded end longer, and use the poorer heat conducting stainless steel, you may be able to drop the temperature at the opening of the heater element below the plastic point of the ABS, so that ALL the melting only occurs inside the metal.
Re: Extruder melt-back woes! July 09, 2010 08:44AM |
Re: Extruder melt-back woes! July 09, 2010 08:59AM |
Re: Extruder melt-back woes! July 09, 2010 11:28AM |
Re: Extruder melt-back woes! July 09, 2010 03:14PM |
Re: Extruder melt-back woes! July 09, 2010 03:31PM |
Re: Extruder melt-back woes! July 09, 2010 03:53PM |
Re: Extruder melt-back woes! July 23, 2010 05:40PM |
Re: Extruder melt-back woes! July 23, 2010 05:59PM |
Re: Extruder melt-back woes! July 23, 2010 08:18PM |
Re: Extruder melt-back woes! July 23, 2010 09:03PM |
Re: Extruder melt-back woes! July 24, 2010 02:06AM |
Re: Extruder melt-back woes! July 24, 2010 04:17AM |
Re: Extruder melt-back woes! July 24, 2010 07:14AM |
Re: Extruder melt-back woes! July 24, 2010 01:47PM |
Re: Extruder melt-back woes! July 25, 2010 03:26AM |
Re: Extruder melt-back woes! July 25, 2010 05:27AM |
Re: Extruder melt-back woes! July 25, 2010 12:53PM |
Re: Extruder melt-back woes! July 26, 2010 09:28PM |
Re: Extruder melt-back woes! July 28, 2010 06:55AM |
Re: Extruder melt-back woes! July 28, 2010 09:49AM |
