Larger motor for less heat?
Posted by epicepee
May 17, 2015 08:02PM
I'm building a machine which will use a stepper motor in an enclosed plastic chamber. So far, I have used a pretty standard NEMA 17 and DRV8825 driver, but even in open air it's gotten a bit hot. To avoid this, I'm considering using a NEMA 23 motor with the same amout of current. The theory is that with thicker wires, it will have less resistance, and will therefore generate less heat, even at the same torque and speed. Does that sound right? If not, how else can I reduce heat generated?
Re: Larger motor for less heat?
May 17, 2015 09:38PM
Are you sure your current is set optimally? If not use this to help you:
[www.youtube.com]
May 18, 2015 01:17AM
I have spent some time, not a huge amount, tuning the current. I do hope to improve that. Either way, though, it's running in a closed plastic chamber. It'll get hot even at its ideal current level.
May 18, 2015 02:37AM
How hot is hot? Can you still touch the motor or is it giving you blisters? Stepper motors can get pretty hot and still work just fine. Just as long as the insulation in them is not damaged you are fine, so for saftey let's say they should stay <60-70°C. That will be still pretty hot to the touch.
Many motors might be able to go beyond that, but keep in mind that if you mount them in printed parts that those will become soft with higher temperatures.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
May 18, 2015 03:01AM
How long are your motors? Other things being equal, longer motors need less current and produce less heat for the same torque.
Power dissipation in the motors is proportional to the square of current, so turning the current down a little makes a big difference to the temperature rise.
May 18, 2015 03:18AM
To answer the question: No it won´t make much difference, because you are still stuck with 12V.
The bigger mass and surface may help to keep it cooler.
But like the others already said: How hot is hot?
-Olaf
May 18, 2015 08:50AM
o_lampe
No, they'll just take longer to heat up. And cool down.
