Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 17, 2015 09:34PM |
Re: Adjusted my pololu boards and now ramps 1.4 board resets when the z probe goes to move May 17, 2015 10:39PM |
Re: Adjusted my pololu boards and now ramps 1.4 board resets when the z probe goes to move May 17, 2015 10:51PM |
frankvdh
What do you mean your "RAMPS board resets"? The RAMPS board doesn't have a processor, so I don't think it can reset.
And "when the z probe goes to move"? Surely the Z probe is physically attached to the hotend so they move together? Do you mean "when the Z axis moves"?
I'd guess that your problem is that your power supply isn't strong enough to provide the required current. And maybe your MEGA2560 board is resetting?
Re: Adjusted my pololu boards and now ramps 1.4 board resets when the z probe goes to move May 18, 2015 12:44AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 09:45AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 10:08AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 10:25AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 10:33AM |
lunarkingdom
yeah but if it was working perfect before for the last week or two? I am pretty sure I shorted something in the vicinity of the Y pololu board, the mega2650 runs on 5v, so does the servo, whatever is going on is in the 5 volt supply.
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 10:46AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 18, 2015 11:57PM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 19, 2015 10:47AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 19, 2015 11:34AM |
ggherbaz
Unless you have a multimeter that can read values higher than 10 amps, you need something like this:
[www.circuitspecialists.com]
Disconnect you heated bed and run the test, if it doesn't reset, then check your bed wiring, if everything is ok, then set your heated bed on a different power supply or get one that can handle everything + 10% more.
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 20, 2015 03:20PM |
ggherbaz
Ok. Then most likely as dc42 said, your 5 volts regulator in the mega board is getting overheated.
Get a cheap LM7805 and supply the power to the servo via power supply instead of the mega board.
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 20, 2015 05:27PM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 21, 2015 12:11AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 23, 2015 06:35AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 23, 2015 10:51AM |
Re: Adjusted my pololu boards and now MEGA2560 board resets when the z probe goes to move May 23, 2015 10:54AM |
